Question about Mitsubishi WD-52628 52" Projection HDTV
Just replaced the light bulb on my WD-52628 and now the picture leans to the right. How do I fx this?
Coldcut
  • 1554 Answers
SOURCE: WD-52628 lamp replacement
the reflector on the new bulb must be the same length/height.
or your beam will be off center normally causing gray areas.
Most likely you did not seat the tray/carrier correctly
be certain the lamp is seated fully.
never touch the lamp with fingers as the oil will make hot spots.
pull out re-seat the tray again.
Posted on Jan 26, 2008
  • 5 Answers
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Posted on Jun 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Posted on Mar 15, 2009
  • 336 Answers
SOURCE: I got a replacement lamp for Mitsubishi WD-52628.
Hi,did you close the door cover? Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Check the fan
was running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on and the red light will blink.
Posted on Nov 18, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd-52628 flashing green timer light
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Color problems
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Feb 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Jan 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
