Question about ION Profile Pro Lp Usb Turntable With Input
Why isnt my turntable spinning when i put the needle to the record
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
Sears model 400.91741 turntable doesn't turn under power. It will rotate when i turn it by hand and the unit is getting power. To start spinning, the instructions say to move the needle arm to the right...
Turntables usually are spun by a 'rubber band' type of arrangement. Look under the platter for a broken belt that would attach to a drive motor and then around the platter. I would contact the manufacturer for the correct belt. You know records are making a huge comeback.
Jan 18, 2015 | Audio Players & Recorders
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
My Philco 841205 Turntable spins but when i put
You need to replace the belt, make a note on how it fits before removing it.
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
My turntable starts in the middle of the record only after me helping it start spinning.
you need a flat key that slots in where the rubber grommit is on the turntable platform. Remove the rubber stopper, use a flat head screwdriver into the slot inside the hole, out an old record on the turntable, and try the play button to see where the arm now lands ( dont forget to put the stylus protector on to prevent needle damage! ) and then keep making small adjustments till the arm starts at the beginning of the record. I actually have an original sony flat key should you want it? but to be honest a long shaft screwdriver is perfectly adequate for the task? email me at lesliemurphy_964@msn.com if you want the key though?
Les Murphy
Aug 15, 2009 | Sony PS-LX250H Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
ION Profile Pro Lp Usb Turntable With Input Logo
26 people viewed this question
Top ION Televison & Video Experts
Electro Med Services...
Are you an ION Televison and Video Expert? Answer questions, earn points and help others
