Question about Cameras
Exchange tops that don't fit
I ordered 2 packs of danskin crew tee..i would like to exchange them
Where does the hose. top-front of carb connect to ?
It probably broke off from a Tee fitting. Three hoses connect at one junction point. After it breaks off, you will only see two hoses that look like a single hose, but with a plastic connector holding them together. Also at that junction point, you will have a hole in the plastic connector, where the hose that came off the carb belongs. This broken Tee fitting creates a vacuum leak. Purchase a new Tee fitting, disconnect the old part, then install the new one.
Jun 07, 2014 | Cars & Trucks
1972 shovelhead oil routing
Bottom of oil tank to right/outside feed on pump. Inside is return line to top of tank where filter cap is. If you ran a cooler than run this line to the cooler and back to the tank. Above the pump is the large vent line. It goes to a tee fitting and than to the top of the tank and to the back/bottom of the primary. The small line goes to the back /center of the primary. It\'s the chain oiler.
May 10, 2013 | Motorcycles
Find a 3 way vacuum connetion booster brake check valve
If you can't find a new valve, you can buy a tee fitting and cut the hose a few inches from the valve. Then add the Tee fitting to get the third connection.
Apr 07, 2013 | Cars & Trucks
I went to gamestop and ordered the escalation map pack for black ops then when i got home i found out it was a code for the first strike map pack (which i already have) is there a way i could exchange?
If Gamestop doesn't let you return it you can always call up Microsoft support and try to get an exchange on the product. And if they don't let you exchange it you can sell the code on eBay so you receive all the money back allowing you to buy the right map pack
May 13, 2011 | Microsoft Xbox 360 Console
Oil dripping from air filter cover when running
Yes this is a real problem with all Harley's but there is an easy for it.
Remove the vent line that runs from each cylinder head to the carburetor, its a metal "Y" with 2 banjo fittings on it where it attached to the top of the cylinders. You can do one of two things here; buy 2 new banjo fittings that have 5/16" hose nipples on them, or you can use what you have and salvage the banjo fittings from the "Y" that you just removed. If you use the old fittings leave about 1" of the old line in place for your new hose. You will also need a 5/16" Tee fitting and about 4' of 5/16" hose. Assemble the banjo fittings, the 5/16" Tee and 5/16" hose to form a new "Y". Then attach the top of the "Y" to the top of the cylinders and run the long end of the "Y" down from the cylinders heads and forward. Follow the front of th motor and run the hose along the bottom right frame rail. I run mine out to the right side of the lower swing arm and then let about 4" of hose hang down at about 20 degrees.
Just take your time running the hose and conceal it the best that you can. Once this is done clean up the mess that the old system left and you will never have oil all over you and the right side of the bike again.
Regards Outback
Apr 25, 2011 | 2003 Harley Davidson FLHT Electra Glide...
I have a 1999 taurus and there is a tee at the rear of the motor that the heater hoses connect to. There are permanant fittings on the tee. The tee has a hole in it. Can I just cut the hoses and put a tee...
Yes, they sell nylon barbed heater hose fittings in a tee. After cutting hoses & attaching to tee with hose clamps. Take zip tie or wire & attach it to bracket for support of hose.
Aug 05, 2010 | 1999 Ford Taurus
I set up a drip system years ago and now am looking to replace it (old, worn, leaks) but the problem is this-I can't push any fitting (be it connectors, tees, etc) onto the main hose. Both hose and...
It's not really a solution-it seems there are two sizes OD (.700", .620") both called 1/2" tubing. The appropriate sized fittings must therefore be used
Mar 21, 2009 | Raindrip R333CT Swivel Tee Adapter
Rheem tanless waterheater cuts of with error code c4 then 13.
Air intake of the unit and or vent termination may be blocked. If the heater worked for that long without a condensate tee. The heat exchanger could be pluged . I would have heater cleaned and have them check out heat exchanger.If you want to take flue pipe off of the top of water heater you can take a flashlight and look down at heat exchanger to see if it is pluged take front panel off first also turn power off if you decide to do this. If you need any help let me know
Feb 22, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Open Questions:
Cameras Logo
26 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
