Question about Saeco Magic Comfort Plus Espresso Machine
The maker does not work instead i get a message says the satzbeh. leeren
I get the message "Rinse unit" I do so and the machine rinses in a normal way. Instead of "Select product" the "Rinse unit" appears again. I can not continue from here. Any ideas?
you might escape this fix without using specially tools or screwdrivers. you are receiving this message because the rinse head sensor isn't working properly.
during the machine movement the rinse head down sensor was not triggered.
1. check the gap between the top of the rinse nozzle & the bottom of the pipette. measurements should be around 1.5 to 2mm
2. you might have to invite the newelectronx 102 to the party and check the sensor. if necessary open the machine with the correct screwdrivers and adjust the sensor. this should get you through the rinse cycle.
Aug 05, 2015 | Franke Saphira Espresso & Coffee Maker
It say satzbehalter leeren
Well, A litteral translation is "Empty Sentence holder"
Clearly the litteral translation of "Satz" to "Sentence" isn't helping us here. You have a holder that needs emptying! Reasonably, since this is a machine that takes litttle plastic pouches of coffee, I'm guessing that it stores them somewhere once they are used and that storage is full and needs emptying.
I'd be interested if you would leave me a comment and let me know how close to the truth I got!
Jun 30, 2011 | Gaggia Titanium Espresso Machine
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
What do I use to clean the calcium deposits in the ice maker? The note inside the machine says to use a bottle of Nickel safe ice machine cleaner by Nu Calgon.....Home Depot doesn't have it....Target...
CLR will work great, just rinse the ice maker very well after cleaning the calcium deposits and throw out the first few batches or bins of ice produced after the cleaning process. Good luck !
Nov 26, 2009 | GE Monogram ZDI15C Automatic Icemaker
HELP I made a movie using Windows (Vista) Movie Maker, was able to burn it to a CD-R and it appears to have burned to a DVD-R but it won't play on my DVD - message says: Playback feature not available
Well it looks like you saved it in the wrong format and belave me I done this as well save it as a MPG or AVI and not WMA or WMV your going to need another disc to burn but we all learn from little mistakes I pray it works for you if not you may need to use like NERO instead or ROXIO is good too good luck to you..
May 14, 2009 | RCA Scenium DVD Player DRX400N
I have a sony camcorder model DCR HC45. i use window movie maker for capturing video device. earlier it was working ok now when i click "capture video" my laptop detects only the web cam a
i understand from the displayed message that "codec error downloading" i must download an appropriate codec pack to rectify the problem . moreover "auto run file" is corrupted. do not know the solution. i am taking my camcorder to sony service centre.
thank you,
prema
May 07, 2009 | Televison & Video
Descaling problem
make sure the * is on the descaling line
Jan 25, 2009 | Miele CVA615 Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
29 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
