Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Salty residue on dishes after cycle, not cleaning properly
My Smeg dishwasher has started to leave a salty residue on the dishes, and does not seem to clean as properly as before. Glasses etc are now cloudy as well, not clean and clear as before.
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
  • 833 Answers
SOURCE: smeg dishwasher
riff...not sure what the bits are...first, they may be food crumbs or the like. Dishwashers have macerators to grind up food particles but they have no really good way to get rid of them in the wash cycle. Scrape plates of any solids before loading them. If the material is shaped like water droplets, you may have hard water stains. Use Jet Dri or a cleaning product which claims to help and use the amount specified. Your water temp may be low...it should be 125F or better. If you can run the hot tap and put your hand under it...it isn't hot enough. You can also use the heated water setting to deal with this.
Posted on Dec 11, 2007
  • 677 Answers
SOURCE: cloudy dishes and hard water
www.dishwasherfilter.com has the solution for this problem. a small filter that filters out the hard minerals that cause these spots before they enter your dishwasher. guaranteed to work and very affordable. your dishes will look amazing. also a money back guarnatee
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: Dirty dishes
check manual,your water hardness and salt/detergent quantities can make a big difference,theres usually some switches you can adjust for salt/detergent,if not check for partial blockage in pump etc,may be not enough water comming through.
Posted on Nov 02, 2009
heatman101
  • 43501 Answers
SOURCE: My SMEG Dishwasher is not cleaning my dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
75osrha
Posted on Sep 29, 2010
Firgidaire dishwasher MODEL FDB641RJSB leaves cloudy residue on dishes. Top spin arm does not seem to be rotating,
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 01, 2011 | Frigidaire FDB125RH Dishwasher
Dishwasher seems to run for a very long time on normal cycle. It leaves a whitish residue on dishes and the glasses appear cloudy. I do use a rinse agent.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 21, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My dishwasher leaves a white residue on my dishes and just doesn't seem to be cleaning dishes right. it is also kind of loud.
heatman101
Oct 08, 2010 | GE Nautilus 24" Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Does not clean well and leaves detergent residue even after several cycles. Tried changing from detergent tabs to gel, no real change.
heatman101
Dec 21, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Salty white dishes
Pour white vinegar into the rinse cycle, this should help.
Apr 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Dishwasher 363.165 model not rinsing right
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
ewe
Mar 11, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Just not cleaning
run a cycle thru with no dishes and 2 cups of vingar this will flush out the unit then run a normal load should be ok let me know THERE also is a product called dishwasher magic you can run that thru as well but the vingar is cheaper
Mar 15, 2008 | Maytag 24 in. MDBH955AW Built-in...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
44 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
