My start/cancel button is not working. I initially had an error message (clean was lit up and S under it) and I called the troubleshooting number and they told me to turn off circuit for few minutes. Did that and pushed "normal" when it was working, cycle stopped with same message soon into it and then i ran the rinse cycle which worked. Then start/cancel button stopped working. I turned off the power again and now it ignores me when I try to get it to run, the cycle switches to speed wash and after couple of minutes it goes blank (not reading start/cancel). What should i do?
SOURCE: Model # GLD4355RFB1 The dishwasher suddenly
I have twice had the machine become unresponsive in a similar way, and in both cases it was due to the touchpad internals or ribbon cable connector (and probably not the main circuit board) breaking or becoming wet. At first glance it seems impossible for such a sealed system to get wet, but a) the ribbon cable goes in via a poorly sealed slot, and b) the seal at/near door lock right next to the slot lets steam out.
Drying (and other) steam is supposed to come out at the _bottom_ of the door. If it comes out the top I think you can suspect the touchpad. I found (the second time around, just last week) that the thing could be fixed with some quality hair dryer time, along with some contact cleaner. I am working on making the door seal better -- just pushing the door firmly closed might actually be enough.
Oh, there is a test mode. From PF or idle, press the Air Dry and Start/Cancel buttons together for a few seconds. It'll then step through the 9 (?) stages in a few minutes, during which various things (pumps, sensors, etc) get tested. You can fast-forward stages by pressing the Start/Cancel button, and errors codes ae supposed to pop up. Oh, better diagnostic docs (which cursorily describe these tests) are in stored inside the front door.
I'm not impressed by the design.
This was for some other GLD4355 machine, but I suspect the family resemblance is pretty strong.
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
mp150 and simular printers:
