Question about LG Revere MobiPhone - Black Verizon Wireless VN-150
How to change number in contacts
Need to change number in contacts. trying to access the edit button
One person in my address book contacts several times with several old numbers and his name several times how do i delete all but one
My daughter is Lisa Taylor!
I can tell you for iPhone and it will be similar on others.
Open Contacts - Click on the Outdated name - Click Edit - Scroll right down to the bottom which is out of view - Delete Contact.
Jan 21, 2016 | Cell Phones
How do you change a contact?
click view contact or the pencil to edit contact. then change the number and save the change
Sep 10, 2015 | Cell Phones
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
Google com
Try these steps:
  • log into your gmail account
  • click on the icon (or your profile photo) in the opper RH corner and click on the "account" link
  • Under the "personal info" tab, click on "edit profile"
  • Click on the "edit" link under contact info to change phone number
  • As you scroll down, you'll see a box that says "details from Google Contacts". Click on the "edit" link to edit your name
Hope that helps!
Aug 02, 2014 | Google Gmail
Cannot edit contact information on my nokia c3
You have to copy all your sim contacts on your phone memory. Then you will gain access to other features like( adding another number,email,picture,ringtone,notes,etc. And you have to check from phone setting which memory phone will use to create the newer contacts, you can let it ask you every time you create a new contact where to save,on phone memory or sim card. Good luck
May 16, 2012 | Nokia C3 Cell Phone
How to reset a password on vizio p42hdtv10a tv i forgot the passwored
Hello
To change password use the number pad and type '0000' or whatever password you have changed it to previously, then press OK.
Actual proceedings are:
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Jul 29, 2011 | Televison & Video
Cannot edit contact info greyt4200@yahhoo.com
I can see how this is confusing. Have you tried clicking right on Contacts? It should bring up a screen showing your list of contacts. Click on a contact for editing. Hope this hopes. Thanks for using FixYa.
Sep 17, 2009 | Yahoo Mail
Update contacts new phone number in blackberry pearl 8230 Also, how to access call history and make the back light brighter
Update w/ new number: Go to Address Book, begin typing name, scroll to contact and select, with contact showing press the Blackberry button and choose "Edit".
Backlighting adjustment: Options>>Screen/Keyboard>> adjust the brightness setting (listed in % 10-100). Then press the back button and Save your settings when prompted
Short call history available by pressing the green phone key.
Aug 01, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
LG Revere MobiPhone - Black Verizon Wireless VN-150 Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
