Question about MSI K8N Neo4 Platinum/SLI Motherboard
Fan does not come on mobo & Fan on video card making a noise
Saw post on somehow using a paint brush to fix the problem...?? I am very pc illit and need explanation in simple understandible step by step terms.the mobo is a K8N Neo4 Platinum/SLI.
    Scholar:
  • 84 Answers
There are many sensitive parts inside your CPU that can be destroyed by simply opening your box/chassis.
*If you are not confident that you can safely open the casing, then you should seek assistance from a qualified technician.
Remove the power cables before proceeding!
The first step in checking to see if your CPU fan is working is to remove the case cover, normally secured with screws at the back.
Most common chassis covers will slide out after the screws are removed.
*Make sure that you maintain contact with the metal part of the chassis to avoid causing ESD damage to your CPU/internals.
Next step, re-attach the power cable and avoid touching the metal chassis this time (there is a risk of shock) before you power on. You should see the fan moving at this point, if it is still working.
Fan not moving? You can take that small paint brush and very carefully run the brush along the fan blades to clear them of dust bunnies. This could also get your fan to run again. It is an immediate solution, but not long term.
It is more adviseable to replace the fan if it siezes or stops working.
Hope this helps.
Posted on Jun 27, 2009
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
Laptop recently started to make noise on start up, feels and sounds like it's coming from the area below the keyboard in the lower left part, it's an acer aspire 5570-2067. it makes noise for a while, then...
Def sounds like the fan , from where you say the sound is coming from . normally the fan should be able to be cleaned the panned holding the fan in the left hand corner . clean the fan with compressed air , or a paint brush . if this fails then you need a new fan .
Nov 23, 2010 | Acer Aspire One PC Notebook
The projector is making a lot of noise. I assume because of dirt in the fan. is it safe to open up & vaccum?
If it is making a noise it is most likely, a faulty fan, you may need to replace it. You could clean it out, very carefully, with a paint brush, and a small nozzle vacuum. DO NOT bang the bulb, be VERY Gentle.
Apr 09, 2010 | Canon LV-S3 Multimedia Projector
Card fan makes noise
Turn off your computer, if your familiar on how to open-up you CPU do so, then,
Try cleaning the fan.
What you can do is clean it with a bush (ex. paint brush-a clean one) or a clean cloth.
you can also try to remove the fan then at the center of the fan there's a sticker, you can safely peel it off then you will see the center of the fan, you can apply machine oil on it, then put the sticker back. Then turn on your computer, let's see if you still has the problem :)
Mar 01, 2010 | Dell Dimension 4600 PC Desktop
So if the ms7528 mobo is not sfe to overclock... but i use like AVGA precision to OC my graphics card(9800GT) would that still cause conflicting problems somehow? I'm new to the OC'ing. I Is it safe to...
I have never used this mobo before have others had problems with overclocking? you could try updating the BIOS/Firmware this might solve the problem. You are correct in saying that AVGA will only overclock your GFX card the bast way to overclock is go up a few Mhz at a time and test it when you hit a point were the PC becomes unstable go back a few steps so your not running it on its limit
Hope this helps tom
Jan 17, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
My pc turns on...but i get nothing..no video..no
I would try another video card.
If NO posting beep then its either RAM / CPU / MOBO
Dec 30, 2009 | Medion Computers & Internet
Msi k9mm-v mobo doesn't post
Remove your memory card in the DIMM slots and insert it again. Reset also your bios. To do this, refer to the motherboard manual.
Oct 27, 2009 | MSI K9MM-V Motherboard
Motherboard dosent working
hi buddy!
maybe the sucket of fan for processor have a problem try to change slot ok this is possible you find that slot is working fine ok.thnx
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 22, 2008 | Acer Computers & Internet
Picture messed up
Try removing the video card & clean the copper contacts with a couple drops of house hold alcohol on a cotton swab. Use canned air to blow out the AGP slot. Blow out the video card's fan as well.
Re-insert the video card & make sure it is firmly seated in the AGP slot. If you're still having the same trouble when you start up, try another AGP 8x card. You're 6800 may be going bad. My bet is the video card is dusty & not seated 100%.
If you are thinking it might be the power supply, don't! When that goes, nothing will work. System restarts by its self can mean the CPU fan is dirty with lots of dust. You can blow this out as well. If it looks real dusty use a clean paint brush to help clean the fan. Don't be too rough with the brush. You don't want to break a fan blade.
Luck!
If the issue continues post back here or click the Ask Me button.
Mike
Jun 28, 2008 | ASUS GeForce 6800 GT 256MB DDR3 AGP 8X...
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
MSI K8N Neo4 Platinum/SLI Motherboard Logo
76 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
