Question about Polarbit Dirtbike
How to fix 1964 comet wireing - Polarbit Dirtbike
Where does the wiring go from the ignition barrel of a 1964 triumph herald
one will be power in from the battery one will be straight to the starter solenoid and one into fuse box possibly depending on whether the ignition dictates if things such as heater fan works
Mar 01, 2015 | 1963 Triumph Herald
I lost the top radial of a Comet antenna model CA-2X4SRB in a carwash - I think. IS THERE A REPLACEMENT for it? Is there a replacement available?
You can easily make your own. I doubt Comet will sell you a replacement. But go to a local cb shop, or ham, radio related place an get yourself a wire to put in socket or mast. I cut down a cb wire antenna an took out the set screw an used my meter to cut it to proper length. Easily done.
Apr 29, 2014 | Comet Antennas CA-2X4SRB Mobile antenna,...
Comet Shredder Comet CM-C-100 will not turn on.
The 'tension ' bar is probably to ensure you have not put in too many sheets at a time, and cuts out if you do. Look at how the bar is fixed at one end then try to reconnect the other end. A good shake of the unit should loosen and free whatever is rattling. If you cannot fix it I doubt Comet will give you much help
Apr 05, 2014 | Comet Shredder Comet CM-C-100 10 Sheet...
Replace the heater on a 1964 cadillac deville
WHY? Is it clogged? Is it leaking? What is the problem with it that makes you believe it is not worth fixing?
Jan 13, 2013 | Pro Tools 1964 Cadillac DeVille Heater...
Cannot register my new UMC tv PURCHASED FROM COMET
Umc do NOT cover any warranty at all from products brought from comet
my TV is 7 days old and broke comet wont do anything UMC wont fix it
Nov 07, 2012 | Televison & Video
How to wire starter to starter solenoid for 1964 chevelle
1964 ,,very eary indeed but its a american car which is not a problem but iam not familar with it as on our europeon cars of this time they never used starter with a solonoid on top (pre engaged) but a inertia centrifugal throw out one ,if this later one is used then i think it will need a special heavy duty solonoid that bolts into the inner wing ,wire from switch goes to this and the + from the battery goes to one aide and the other to the starter ,quite simple but have you got all the right parts if it is this type
May 11, 2012 | Chevrolet Cars & Trucks
El diagram til pgo comet
my moped starts but does not running. period 6 mounths was in garage and did not use then, battery and spark plug and etc are ok, I think for cold weather and long time that was not in use . how to solv this problem+
Jan 24, 2012 | 2008 PGO Comet 50
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Polarbit Dirtbike Logo
448 people viewed this question
Top Polarbit Apps Experts
Are you a Polarbit App Expert? Answer questions, earn points and help others
