Question about Frigidaire Washing Machines
Wiring diagrams for affinity front load washer
Pictures of wiring connections
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that you are look for the wiring diagram for your Frigidaire Affinity washer. The wiring diagrams are typically not accessible to the public. I suggest contacting the manufacturer, as they might have access to that wiring diagram for your appliance. Hope this is helpful.
-Best Regards-
WP
Posted on May 16, 2014
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
MakeupWizard
  • 39 Answers
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Posted on Apr 22, 2010
  • 1382 Answers
SOURCE: What does the code E10 mean? The washer flashes
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Posted on Jun 28, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
  • 196 Answers
SOURCE: How do I access the drain pump on a Frigidaire
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Posted on Mar 01, 2011
Control board
Good Morning Dan, thank you for your post!
I have located the wiring diagram for the above-post Frigidaire washer, ATF7000E on the manufacturer website. I do hope this information proves helpful! If you need further help, please feel free to reconnect.
Dec 07, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
I have a frigidare affinity front load washer the drum seems very loose is this normal?
yes as it it is spring loaded ,thier is only one bearing at the back but the support mounts are all spring loaded ,you could get someone to take the top off and make sure that the springs are all connected and one of the support brackets on the drum isnt broke off
Dec 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidaire affinity front load washer that will not lock and start. I turn the dial, all pertinent lights come on, but no door lock and it alternates between cycle time and "Pau" which...
is there any water in the drum if no then it could be your door catch try shuting the door with a bit more force or pushing on the door when you turn on the machine if it does not start then it will be that you will have to replace your door catch
Oct 15, 2011 | Frigidaire Affinity ATF7000E Front Load...
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity front load washer doesn't start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
What does a E-40 mean on my Affinity front loading washer?
It was a loose wire connection and I fixed the washer.
Mar 27, 2009 | Zanussi ZWF1430W Front Load Washer
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Jun 20, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
185 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
