Repair icm282 board
Control board
What does LF flashing red mean
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
My Kitchenaid refrigerator KSSC48QMS is humming and cuttung on and off. ????? the lightz blknk when you open the door?
First of all the flashing lights on the panel indicate a problem with the communication between the board and the evap fan motor. Now I would have a certified service person repair this as it will require the control board that needs to be sent in for repair and a fan replacement. Both part need to be replaced at the same time or this issue will not be corrected properly. Your fan has failed and took out the control board is what happened. Evap Fan motor part number is W10255195 and the control Board part number is 2252159, the board is fixable and would need to be removed to be sent out to repair (2 weeks down time is normal). The company who repairs the board is Corecentric Solutions 866-737-2244 or www.corecentricsolutions.com. Rough estimate to repair is 175.00 board including shipping, fan motor about 100.00 or so and the labor to change parts as some installation of the units are difficult to change parts inside a closed cabinet, some units have to be removed to access control board in top of the unit. I hope this helped, I own this model and repair these units as well. Good Luck
Aug 17, 2014 | KitchenAid 30 Cu Ft Architect Series II...
Frigidaire dual fuel range plcf489ccd oven temperature display
It seems that Range Control Board 3108010102 is not working. You would need to get the board repaired since it is no longer available from Manufacturer. You can get the board repaired from www.partsimple.com at lowest price as compare to the rest of online competitors.
Here is the direct link for your board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Jul 04, 2013 | KitchenAid Kitchen Ranges
New Control Board or can it be fixed?
it can repaire.....replace that micro switch......
Jun 05, 2013 | LG Washing Machines
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
Matag neptune front load washer MAH4000AWW tumbles but won't spin dry. I tried it with and without clothes in the wash.
Jan 22, 2010 | Washing Machines
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
