Question about GE Profile JTP18 Electric Single Oven
F7 code We have an f7 code after a service man replaced the circuit board behind the key board for the 2nd time. Could there be another solution?
  • 5 more comments
  • tweetybird2 Dec 21, 2007
    f7 continues to beep. We disconnected the fuse for a few minutes and reset the fuse in the garage. All was fine until I used it again today. What's up with this?
  • Anonymous Feb 17, 2008
    This weekend, our oven keeps beeping and displaying the F7 code. At first it occurred every few hours and we could still use the oven. Now, however, it is beeping every few minutes and the oven will not work at all! What is your advice? We had company coming for dinner tomarrow night and would sure like to use our oven. Thankyou for your help!
  • AlasKen Feb 25, 2008
    I had the same problem and fixed it in less that 5 minutes using powermans solution.
    www.fixya.com/howto/h155060-dreaded_f7_error
    Try that next
  • rosie20 Mar 18, 2008
    Same F7 code problem with beeping noise and oven totally non-functional.
  • Motzaman Apr 02, 2008
    F7 Error code comes and goes. When F7 ia around the oven usually can't be used since it seems that the keypad is locked up. Looking for a solution to this problem.
  • glennhelp Mar 11, 2009
    I HAVE THE SOLUTION FOR THIS PROBLEM. THERE IS DEFECT IN THE RIBBON CABLE TO THE KEY BOARD. IT SHORTS OUT WHERE THE RIBBON GOES THROUGH THE METAL SLOT. JUST INSERT A PIECE OF CARDBOARD TO INSULATE THE RIBBON CABLE FROM THE METAL CHASSIS. IT HAS WORKED FOR ME FOR 2 YEARS NOW. NO MORE F7 CODES TRUST ME.
  • falcneddieny Apr 01, 2009
    gejtp20 f7 code replaced the control worked for 5 min. Is it ribbon short on metal or keypad
  • 248 Answers
This code is more often a bad keypad. Have him try that. We will try keypad before main board, based on past experience.
Posted on Nov 04, 2007
Kenmore wall oven digital screen is blinking F7? it has a digital button screen. i can clear it but it comes on again a minute later. no other buttons work?
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 19, 2010 | Kenmore Ovens
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Oct 05, 2010 | Kenmore Ovens
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
I have a Jenn Air Oven micro combo wall unit.The oven shows an error code F1/F7 with continuous beeping. I have to turn power off to get rid of it. But then I cannot use the mocrowave-any solutions?
Hello- The code described F1/ F7 indicates a 'stuck' key on the control panel. The problem is fairly common, and is not caused by computer. The panel is actually more expensive than the computer. On site diagnosis is needed to confirm. The switch is on a circuit board behind the panel and is not serviceable. Find a good service tech in your area to check it out. Wish I had good news, but I installed several of these under 1 year warranty period.  So- let me know if this info helps- have more if needed.   Thanks- Ed
Mar 17, 2010 | Jenn-Air JJW8530C Expressions Collection...
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
F7 flashing on our oven screen
Without the model and brand I can only give you the most common F7 Error code. F7 for the most part on a oven is a stuck key on the key pad and can also be a control board. Some key pads are part of the control and you will just need to replace the control.
Sep 26, 2009 | Magic Chef 9815 Electric Single Oven
F7 screens flash and beep,but not every time we use range
There's a lot of info missing here, but any tech should be able to tell you what the F7 indicates. Each F code indicates a specific problem. In my case, an F-1 indication which says the circuit board has a problem, was resolved easily by fixing a problem with the momentary contact convection oven switch. You may have a faulty switch like that which could be causing the problem--in all likelihood, it was NOT a circuit board problem. If it was, then it was caused by another problem somewhere else, and they owe you a new circuit board, and a repair on whatever is causing the circuit board to fail. But more than likely they owe you a refund for the board you bought, and a fix on whatever is causing the problem....
Jan 29, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
CODE F1 AND OVEN DOES NOT WARM UP ABOVE 250
looks as if th ef1 only pertains to the erc(electric range control), the switch membrane qould be an f7 (shorted key pad, the oven sensor os diff code all together
Feb 26, 2008 | Amana AOCS3040SS Electric Single Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
GE Profile JTP18 Electric Single Oven Logo
347 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
