SOURCE: leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
SOURCE: I have a homelite leaf blower model ut08544 that will not start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
