Question about DeLonghi Heating & Cooling
My PAC-10 no longer blows cool air. In addition, the condensation pan never fills up with water anymore.
I purchase the air conditioner used on ebay ( I know not very smart) about a year ago.
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
Water does not evaporate why?
That air conditioner has a cooling coil that drips water into a formed plastic pan at the bottom that the coil sits in. The condenser sits in a pan similar to the pan previously mentioned. The pans are connected by a tube that allows the cooling coil water to find its way to the outside area under the condenser. The condenser fan outside has a ring attached to the end of the blades called a sling ring. As the fan spins it picks the water up and "slings" the water against the condenser thus getting rid of the water through evaporation and giving the air conditioner an additional 13 percent more capacity. If you drill drain holes I have seen units quit working because that additional capacity is engineered into heat rejection. Hope I helped good luck.
Oct 09, 2014 | Amana AH123E35AXAA 11,600 BTU Room Air...
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
ALGEA AND WATER HAVE BUILT UP INSIDE AIR CONDITIONER - HOW TO GET OF IT
Spray everything down with a clorox and water solution in a spray bottle. Mix 1 part clorox to 10 parts water. Then place a few ounces os clorox in the water in the drain pan. Many window a/c units are leaving water in the pan and using it to help cool the condenser coil now. Not really a great idea in my opinion.
heatman101
Aug 20, 2010 | Haier hwr10xc6 Air Conditioner
Regarding the delongi pac 50 is it vital to have water constantly in the machine when it is on? if it is on and there is no water in the container will it burn the machine out?
The water in the machine comes from the cooling coil, and is condensate. This happens with all cooling systems. And no, no water in the cup will not burn the machine up.
Please reply if you are having problems with the unit.
Dec 17, 2009 | DeLonghi Pinguino PAC-77E Air Conditioner
Water droping
Your drain pan is not draining. Use a wet vac to **** the drain line from the outside. This will pull out the blockage and you're back in business. Do not blow compressed air into the drain. This pushes the blockage back up into the drain pan.
Oct 02, 2009 | Friedrich M18YE Air Conditioner
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
20 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
