Question about Copystar CS-1820 Copier
Kyocera cs1820 error 6400 - Copystar CS-1820 Copier
  • 523 Answers
Fuser unit problem try to reset it by using mode 163, if it doesnot work change the fuser unit
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jul 06, 2009
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Tengo una kyocera 1016 sale error call 6400 como elimino es problema por que nesecito solucion gracias
Code: 6400
Contents: Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB.
- Defective the engine/high voltage PWB.
Feb 09, 2011 | Kyocera FS-1016 Printer
Kyocera cs1820 has unknown id and password how can i reset so i can use this copier?
Refer to the Advance Operators Guide page 6-1. You can download the manual at the following link;
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774.
If yo need additional help call Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482 There is no charge.
Jan 06, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
input within 3 s.
Causes:
Dec 15, 2010 | Kyocera FS-1016 Printer
How to connect a Kyocera CS1820 as a network printer
Hook up a cat 5 cable from a network switch and load the driver on each workstation
Jun 19, 2010 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera cs1820
c 7980 is a warning that the waste toner container on the imaging unit is full, This usually means the life of the imaging unit is finished or close to being finished. If u dont want to replace it yet, a quick way is just to empty it. on the left and right of the unit at the back you will see 2 screws take those out then remove the small covers and just poor the toner out(DONT BLOW INTO THE UNIT). put tje covers back on, clear off any spilt toner and put the unit back into the machine
Aug 14, 2008 | Kyocera Copystar CS-1820 Black and White...
142 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
