Question about Mitsubishi WD-52525 52" Rear Projection HDTV
What is the problemthe picture is dark the quality is fine but dim
Our Lg Plasma 50PC1DRA popped then a very dim picture
If you have the same problem with another input such as a DVD player, this TV might need attention by a qualified service technician.
Aug 05, 2012 | LG 50PC1DRA 50 in. Plasma Television
Colours have gone and picture quality became very dark. Now wont stay on for very long...will switch off after about 10 mins of viewing.
Unfortunately dim image and premature shut-off are normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image/premature shut-off.
Aug 01, 2011 | Panasonic PT-AX200U Projector
Everything works fine, just going dark on me!
Yes, anytime the picture becomes dim, or the color begins to fade it is time to replace the lamp.
Mar 17, 2010 | Eiki LC-SB20 Projector Multimedia...
Picture dims dramatically
I have the same problem so far the best I could do was to put the user setting to sports and brighten up the tv as much possible without making the picture look too bad. Good Luck
Aug 02, 2009 | LG 22LG30 22 in. LCD HDTV
Very poor quality pictures; grainy.
This is easily fixed - go into MENU and you will find a picture quality Q. This is designed to go from FINE - Medium - POOR in order to enable you to take more photos on you cameras memory. Install at least a 1gb memory stick into your camera and then choose HIGHEST QUALITY you will now be able to get plenty a photos at the highest quality possible gor the camera with an 8.2 megapixal those photos should be really nice. Have Fun Lancer721
Dec 07, 2008 | Fuji Finepix J50 Digital Camera
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
