Question about Panasonic NN-P295SF Microwave Oven
How to change from outside venting to inside for panasonic over the range microwave oven for
MicrowaveSvc
  • 9047 Answers
SOURCE: range light and oven vent fan
This usually indicates damage to the circuit board of the control unit assembly. We repair these control units nationwide for only $32.50 postpaid. If you decide first to remove or replace the bulbs or check the sockets or wiring, please unplug the microwave first. Failure to do that is usually how the boards get damaged. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can usually find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 BUT - I don't recognize NN-2501 as a valid model number. Could you confirm that? Thanks!
Posted on Feb 19, 2007
fridgetech
  • 473 Answers
SOURCE: Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
SOURCE: i have a panasonic range
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Posted on Aug 14, 2008
SOURCE: panasonic NN-S740BA Microwave oven
In all likelihood the mangnetron is failed or failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Posted on Jan 27, 2010
  • 6771 Answers
SOURCE: I have a Panasonic over
This not a good sign, from your description it indicates the high voltage transformer is shorted possibily caused by the magnetron becoming defective. The money would be better spent replacing the microwave oven, the repairs to the present unit will be close or exceed the cost of a new one.
Posted on Jun 22, 2011
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
I have a Panasonic over the range microwave (1100 Watts) purchased in 2008. There is no heat coming from the inside of the microwave, however there is a large of amount of billowing smoke coming out of...
Jun 22, 2011 | Panasonic NN-H275 Microwave Oven
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Is there a piece I can install on the bottom of my over-the-range microwave that will help keep the front of the microwave from being covered in steam when cooking on my stovetop?
Every over the range microwave has a vent on it that should be venting that steam. I don't know of anything you could put under there that would solve your problem as that is where then vents are and they would be blocked. It sounds to me as though your steam is not being vented properly, and this could also happen if the steam is being vented back into the room instead of outside as many OTR microwaves allow you to do. Its a little bit of work to vent it outside but I myself did that with my microwave and have never had a steam accumulation problem.
May 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
I'm trying to remove but unable to determine how
most over the range micos are secured by either 2 or 4 screws from above usually inside a cabinet or storage above remove those disconnect or pull away venting if vents above,, u willl need two people sometimes to help hold micro..... i would have to see the unit some might also have trim pieces if its more of a built in situation hope this helps
Jan 31, 2010 | Panasonic Microwave Ovens
Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Dec 05, 2009 | Samsung Microwave Ovens
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
26 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
