Question about RCA DRC277 DVD Player
Rca model rtd3266 wont produce sound through regular tv
2 Suggested Answers
  • 36514 Answers
SOURCE: rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Posted on Nov 30, 2013
I need an owners manual for a RCA RTD3266
Chekc the links bellow
http://www.manualsonline.com/
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jul 10, 2015 | RCA Audio Players & Recorders
When I plug in my RCA model rtd3266 home theater, all the lights on the front of the box flash on and off. Nothing I do on the box or remote has any effect.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 23, 2014 | RCA Televison & Video
I need help with volume and popping and cracking in the speakers. It's a new system and it's only plugged into my record player.
You are most likely going to need a preamp to go between your home theater and record player. The popping and hissing is usually a grounding issue. You will have to ground your system properly to get rid of this.
Dec 21, 2014 | RCA Audio Players & Recorders
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
Nov 30, 2013 | RCA DRC277 DVD Player
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
How can i hook my pc up to get sound threw tv and dvd w/surround sound
You would need the following hardware from radio shack.
Male 3mm jack to RCA into the back of the tv.
Depending on how far the TV if from the computer would depend on size of cable.
Now you tv has surround sound?
Or
You want the computer to produce surround to your tv?
I would go with the RCA idea to give you some starting place to produce sound from the PC to the back of the TV. Now this same idea goes for hooking up mixers, amps, ECT
I hope this helps you in your projects
Thanks for using Fixya.com
Jun 30, 2011 | RCA Electronics - Others
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
My RCA Scenium HDLP50W151 TV makes is making a loud whining sound that varies in degree. I have picture and sound but the noise is beginning to drown out the TV volume
All projection TVs for RCA are DLP TVs, with that in mind these TVs have a lamp inside that produces white light. The color wheel is the one in charge of giving color to that light. Regularly the color wheel last between 2 to 5 years depending on the daily tv use. Most of the time when the central barring of the wheel is loose, unstable, or out of place it will cause the edge of the wheel to make contact with the housing, producing that whining, whirling, screeching or hissing sound. These sounds can either produce just a annoying sound when watching tv or can cause the tv to shut off. When this happens you’ll have to replace it, if you want to know where to buy, you can look in ebay, there are many parts you can get at very good bargains, the only thing is that you buy at a high risk of the part not working ( I had a bad experience). The other option is to buy at an electronics store online dedicated at selling tv parts, some can help you trouble shoot your problem and others may have tech support over the phone (personal recommendation: Discount-Merchant.com ). And last remember to search your part by part number, NOT by model number, two TVs with same model numbers but assembled on different dates ( different generation TVs ) will have none compatible tv parts inside, so be very carful.
Dec 24, 2009 | RCA Televison & Video
My tv has sound but no picture
Check to see if you aux inputs pass the audio and video. If you see picture and have sound then your problem is most likely the tuner.
Jul 06, 2008 | RCA P52921 52" Rear Projection Television
Tv wont turn on p52960
Still sounds like the flyback. Rca has had issues throught the years with flybacks failing especially that model.
May 12, 2008 | RCA P52926 52" Rear Projection Television
RCA DRC277 DVD Player Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
