Question about Nilfisk UZ 934 Vacuum
Uz934 motor diagram - Nilfisk UZ 934 Vacuum
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
I need a parts diagram of a dyson dc 18 that I can read. Please help.
Sorry we do not have this diagram. Contact Dyson, whom I suspect is not going to be very helpful based on previous experiences
Oct 11, 2012 | Dyson Dc-18 "slim" Upright Model...
Power intermittent: when cable is touched power returns
You have a broken power cord. Hoover is notorious for power cords. I'm speaking from personal experience. Replace/have the power cord replaced.
May 08, 2012 | Vacuums
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
I have a kenmore canister model number 116.2645083 I need a replacement motor. I was given 2 different numbers: 1. 4147248 2. AC92FAUX200 I can find the 2nd motor, but it doesnt have the 4 wires like the...
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
I Need a Wire Diagram for my Oreck XL3600HH!!!
I emailed that diagram to you, hope it helps.
Apr 14, 2008 | Vacuums
Nilfisk UZ 934 Vacuum Logo
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
