Question about Canon imageRUNNER 1023iF Black and White Copier
How to find IP address
I have a cannon image runner 1023if - how do i find the IP address ? It is connect thru a network - not to a computer.
    Champion:
  • 215 Answers
You may check your internet speed test.......
Posted on Nov 12, 2010
    Sniper:
  • 93 Answers
U want to know local netwotk ip address U go to cmd- and type ipconfig and then u want to know internet ip address u go to this site ip-details
Posted on Jul 03, 2009
  • Canon Expert
  • 398 Answers
Print the config page, is the easiest way -Carl
Posted on Jun 28, 2009
I don't have the installation disk for my Canon ImageRunner 1023iF Copier and so I downloaded the online drivers. I still can't get my computer to show the Canon under printers. How do I get it installed...
Install the downloaded driver. There's an option if your machine is connected on a network or directly connected to a computer using USB. If you choose connected on a network, you should manually set the IP address. If you choose USB, the driver will detect the machine automatically.
Nov 12, 2010 | Canon imageRUNNER 1023iF Black and White...
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
How do I do a code reset for the imagerunner 1023if. I need to reset my IP address to a network IP address.
If you have the current ip go to internet explorer with pc, press ctrl and O a window will pop-up, type the address of the copier and press enter. This is the remote user interface, login as administrator and you can change settings from here.
Apr 20, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon image runner c3100 switched to dynamic ip addressing on new router but now ir c3100 does not work , i gave the printer an ip address and i can ping it from my computer and when i send print packets...
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 16, 2009 | Canon imageRunner C3100 Copier
Discovering network scanner
hello .
try to ping the machine on the CMD prompt .
put the ip as static and try again.if you still cant detect then see your network .
Oct 07, 2009 | Canon imageRUNNER 1023iF Black and White...
DOES NOT CONNECT TO NETWORK
Sounds like the 600 is waiting ofr a DHCP server to give it an IP address, do you have aDHCP server on the network? If no then you will have to manuall assign the IP address.
Aug 07, 2009 | Computers & Internet
ScanGear Not Detecting Network ImageRunner
the scangear by network is not for this machine .only for usb.
May 20, 2009 | Canon imageRUNNER 1023iF Black and White...
Printed 2 sided copy now everything is printing 2 sided ITS STUCK
If you printed this from the PC you might have changed the default in the printer driver. Browse to printers folder then right click and choose Print Preferences. Look for 2 sided selection and make sure it hasn't been changed.
Hope this helps,
TankMurdock
Mar 20, 2009 | Canon imageRUNNER 1023iF Black and White...
Cannon Image Runner 1023iF will not send or re: a fax
First try to check your fax settings.Your 'line settings' has to be set to 'tone' and not "pulse".
Set your fax mode for "fax only"
And try again.
Jan 20, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon imageRUNNER 1023iF Black and White Copier Logo
663 people viewed this question
old marine
old marine
