Question about Air Conditioning and Heat for Kia Soul
Fan does not blowall the time - Air Conditioning and Heat for Kia Soul
    Problem Solver:
  • 18 Answers
Blower resistor wiring sometimes overheats and melts the connectors attached to it. Check these first. Resistor is usually attached to heater box.
Posted on Aug 19, 2014
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Panasonic TC-P50VT25 1 yr 3 month old powers off after 30 secs blinks 11 times pauses blinks 11 times and continues
The issue suggests either no voltage to that fan or it is bad--most of these all fans are powered from the same source.
I have seen this before---try swapping fans if they are identical--if another where you swap it now does not work--fan is bad.
Usually we (in the shop) if find this change all three fans.
Mar 20, 2012 | Televison & Video
The fan motor is on all the time with the controls shut off. I have to shut the unit off with the main breaker. The ac works but again the fan never shuts off. On the circuit board the LED flashes 8 times,...
The indoor fan or the outdoor fan? If it is the indoor fan the thermostat may be wired incorrectly or shorted. If the red wire and green wire in your thermostat maintain contact, the indoor fan will run all the time.
Aug 03, 2011 | Heating & Cooling
Noise some times and fans dont work some times
99 out of a hundred times - when the fan motor on a window unit 'makes noise and works intermittedly,' you have a bad fan motor which will require replacing.
Sounds as if the fan motor's bearings are making noise - which - would account for the fan working only part time. The reason being is that the 'bearing noise' you are hearing - is a result of the bearings being wore out - thus it causes the fan motor to heat up and 'go off' - on the internal overload' which is built into the fan motor.
Like I said above - most commonly the 'fix' is to replace the motor.
Jun 09, 2011 | Frigidaire FAC106P1A Thru-Wall/Window Air...
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
    NOTE: Replace tensioner spring if timing belt deflection is excessive.
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Aug 02, 2010 | 2001 Kia Sportage
Fan not moving fast
mcdevito75 here, The small pull chain you use to turn the fan on is also the fan speed switch, simply pull that cahin 1 more time and then 1 more time after that for various fan speeds.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Fan runs all the time
I HAVE HAD A COUPLE OF UNITS THAT HAVE KEPT THE FAN RUNNING ALL THE TIME. I REPLACED THE CONTROL AND THAT TOOK CARE OF THE PROBLEM.
Mar 09, 2008 | Whirlpool AD70USS Dehumidifier
Air Conditioning and Heat for Kia Soul Logo
73 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Todd Arndt
Todd Arndt
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
