Question about Pioneer AVIC-D3 Car DVD Player
Why does my AVIC 5000 NEX break up when connected to iPod ?
My ipod wont play on my AVIC F910BT
I don't know if you fixed it already this iPod sound trouble, but I got ot also and found how to fix this trouble.
In fact there's a setup to do and mention in the User Manual (page 89 on the english one) the AV1 config should be selected as iPod
Using an iPod (iPod) Starting procedure
Connect your iPod.
No sound or video output if iPod is selected
as AV source, check the setting in “AV1
Input” on the “AV System Settings” menu.
Dec 25, 2009 | Pioneer GPS
How do i hook up my ipod touch to the avic f700bt
You will need an accessory cable, part number CD-IU230V This connects to the back of the unit and then to the iPod or iPhone. Typically the iPod end is fed through to the glove box or some such other handy place.
Jul 08, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Ipod Touch 16g
Try resetting your Ipod. I had the same problem with 3 different Pioneer head units. This solution worked just fine.
You also might not want to connect or disconnect the Ipod when the head unit is on.
Jul 02, 2009 | Pioneer AVIC-N4 GPS Receiver
How do i hook up an ipod to the pioneer avic-n2
unit should comes with ipod connector if not you have to buy and connect to back of unit
Jun 26, 2009 | Pioneer AVIC-N2 Car DVD Player
Cant get ipod to work on avic=n2
I have reset the systems before WITH the new ipod cable connected. Try that, I know that it will reset everything, but that has worked for me as it sees all the new hardware through IP bus
May 31, 2009 | Pioneer AVIC-N2 Car DVD Player
How to remove avic d3 to connect iPod wire.
it probably unclips from the dash, but you have to slide the player out to put the wire in
May 13, 2009 | Pioneer AVIC-D3 Car DVD Player
How to work the ipod on pioneer avic f900
Hi my name is Juan and let me splain to you what is going on you are connecting your ipod using only USB and the ipod is protected is not like any other mp3 players on mp3 players you can output sound trow the USB but not on ipod apple don't want you to connect your ipod to another computer using USB and transfer your music to another ipod so if you want to lessen to your ipod using this stereo you need to buy an special cable that connects in the back of te receiver is designed for ipods go to ebay and type pioneer f900bt and go to accessories you will fine one there for around 35dls I have the same system you got and what I did is I purchase another 4GB mp3 those regular mp3 from china THEY CAN PLAY USING ONLY USB
Mar 25, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Hello, I have the pioneer AVIC 700bt. When I plug my Ipod nano into the USB adapter on the head unit, the Ipod display comes up right away and it shows that it is playing but there is no sound coming...
You will need to be using the CD-IU230V cable for the iPod.
After connections, you will also need to follow these step:
Press "menu".
Press "settings"
Press " AV Settings"
Press "AV1 Input" multiple times until it says iPod.
You will now be able to hear the sound from the ipod when it is selected as a source.
Dec 26, 2008 | Pioneer AVIC-F700BT Car GPS Receiver
Ipod problems with Pioneer AVIC-D3
Do you have an ipod module or are you using ibus-to-rca cable to connect your ipod to the D3? In order to control full ipod functions by touch screen you need the ipod module, hence the D3 says ipod control ready not ipod control built in. Let me know so I can pin point the problem.
May 01, 2008 | Pioneer AVIC-D3 Car DVD Player
Pioneer AVIC-D3 Car DVD Player Logo
48 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
