Question about Garden
The rubber gasket that goes between sprayer and pump
Hudson eliminator home and garden sprayer model 30161 rubber gasket between sprayer
4 Suggested Answers
  • 332 Answers
SOURCE: I have the hudson eliminator sprayer and squeeze
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Posted on Mar 08, 2010
jyackle5
  • 8197 Answers
SOURCE: how do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jun 27, 2010
SOURCE: No pressur in my home and garden sprayer
You have a leak. First ensure the pressure relief valve is closed. You can try spraying soapy water on the outside while pumping it up, and look for bubbles. The one way valve might be leaking, too. Good luck.
Posted on May 23, 2012
Hudson parts for 30161 sprayer where to buy
Direct, eBay, Amazon.
To speak with an expert, please call 1-800-9-SPRAYER
and someone will assist you with your inquiry.
Product Search ' H. D. Hudson
www.hdhudson.com/product-search
Hudson® Universal Maintenance Kit Model 6972. One Kit Repairs over 90% of Hudson Sprayers with Genuine Sprayer Service Parts! 6972 Hudson® Universal Maintenance Kit. View Product Details ...
HD Hudson: Home
www.hdhudson.com/ HD Hudson Manufacturing Company is the world's leading manufacturer of innovative, high quality, consumer and commercial sprayers and sprayer systems.
Product Details ' Hudson® Universal Maintenance Kit ' H. D. Hudson
www.hdhudson.com > Product Search Simple parts kit offering - one kit repairs over 90% of all Hudson® sprayers! Contains necessary parts to rebuild the majority of both metal and poly sprayers. In most cases, kit will upgrade existing components on customer's sprayer; Contains Viton® O-Rings, TOV™ Thumb Operated Valve, Pic-A-Pattern™ Fan/Cone nozzle ...
Product: Hudson Eliminator Sprayer - 1 Gallon, Model# 30161
https://www.northerntool.com > Sprayers > Handheld Sprayers Item #268137 is no longer available. Hudson Eliminator Sprayer - 1 Gallon, Model# 30161. Find Similar Items. Replacement Parts Available. More Info · Find Parts ...
Hudson Pump Sprayers Parts: Amazon.com
https://www.amazon.com/slp/hudson-pump-sprayers-parts/2naarhymmyr79cg
Buy products related to hudson pump sprayers parts and see what customers say about hudson pump sprayers parts on Amazon.com ? FREE DELIVERY possible on eligible purchases.
H. D. Hudson Manufacturing Company Online Store
hudson-sprayer.com/ COMPRESSION. SPRAYERS. ? Locate Sprayer Parts · ? World Health Library · ? Newsletters. This equipment has been found to comply. with the performance guidelines of the. World Health Organization Specification. number WHO/VBC/89.970.
Hudson Sprayer ' eBay
www.ebay.com/bhp/hudson-sprayer Find great deals on eBay for Hudson Sprayer in Find More Garden Tools & Equipment. Shop with confidence. ... Hudson 62062 Bugwiser 2 Gallon Sprayer Galvanized Steel,No 62062 Hudson, H D Mfg Co 62062 029925620629. ItemWeight: 5.59. ... Hudson Brass Extension Wand with Nozzle Trigger & Parts Set. $18.00.
H D Hudson Sprayer Parts - Sears
www.sears.com/search=h%20d%20hudson%20sprayer%20parts Items 1 - 37 of 37 - Hudson H. D. Hudson Manufacturing Company H. D. Hudson 96302E H. D. Hudson Comando Sprayer, 2 Gal, 18 in Extension, 42 in Hose 96302E Pack of 1 · 0 · Sold by SIM Supply · Hudson H. D. Hudson Manufacturing Company H. D. Hudson 20012 H. D. Hudson Multi-Purpose Poly Sprayer,. $31.13 ...
Hudson Sprayer: Amazon.ca
https://www.amazon.ca/slp/hudson-sprayer/e675o8k2yzys3u8 Buy products related to hudson sprayer and see what customers say about hudson sprayer on Amazon.com ? FREE DELIVERY possible on eligible purchases.
Hudson Universal Maintenance Kit
Apr 07, 2018 | Coffee Makers & Espresso Machines
How do I assemble a Hudson eliminator 30151?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Chapin Home and Garden Premium Nozzle Kit...
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
How do i fill my hudson sprayer
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
Pressure is good, but very little spray is shooting out
you need to take your wand nozzle apart and clean it thoroughly. I would recommend taking it apart and making sure the entire unit is clean. Depending on what you spray through it, or how often you use it. May have to clean it more often.
Nov 06, 2009 | Eliminator Hudson Sprayer - 1 Gallon,...
How to remove lid
The only way that I know of is to hold the bottom part (jug) securely and turn the pump handle. If you put some pressure on there and just hold firmly it should eventually start to unscrew. You need to push the pump handle down as far as it goes and it will lock into some "ears" on the pump assy so it will turn the pump assy as well.
Sep 06, 2009 | Eliminator Hudson Sprayer - 1 Gallon,...
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
