Question about Dell Latitude D505 Notebook
Lock and battery indicators flashing - Dell Latitude D505 Notebook
03 micra central locking inop.
You may have to have it flashed at the Nissan dealership, they can reprogram the fob.
Jul 07, 2014 | 2001 Nissan Micra
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
My bmw 320d remote wont lock car however does lock the car with the key its a 55 reg
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
Later keys with bmw badge on key. Battery can not be replaced
Battery in key charges while driving
Dec 22, 2010 | BMW 3 Series Cars & Trucks
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Need to reset the key fob after replacing the battery
You should not have to reset the key fob after a battery replacement. The signal from the key fob stays the same and is programed to the reciever.
If the key fob needs to be reprogrammed then follow these steps.
1. Have all key fobs with you during programming.
2. Sit in the vehicle with all doors closed.
3. Lock all doors using the Lock/Unlock switch on the door.
4. Insert and withdraw the ignition key 7 to 9 times within 10 seconds (do not turn the key, just insert and withdraw).
5. The 4 way flasher indicator on the dash should flash once or twice.
6. Insert the ignition key and turn it on (key on, engine off).
7. Press any button on one remote and the 4 way flasher indicator on the dash should flash once.
8. If you have more key fobs to program use the Lock/Unlock button on the door to unlock the doors and then lock the doors.
9. Press any button on the next key fob and the 4 way flasher indicator on the dash should flash once.
10. Repeat if you have more key fobs. Only 5 can be programmed.
11. To exit, simply turn of the igniton and remove the ignition key.
12. Unlock the doors using the Lock/Unlock switch on the door and exit the vehicle.
13. Make sure the window is down when testing remotes in case you leave the keys inside.
14. Close all doors and test all remotes that were programmed.
Do not skip any steps or the process will not work.
If the 4 way flasher indicator does not work when inserting the key, you will need to start the process from the begining. If it still does not work the receiver may be your problem.
If the 4 way flasher indicator does not flash when pressing any button on the key fob then the key fob is the problem (dead battery or defective remote)
Dec 18, 2009 | 2002 Nissan Xterra
Dell latitude d505
It is the caps lock  I don't know why it is flashing though
Dec 02, 2008 | Dell Latitude D505 Notebook
Set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Nov 12, 2008 | 2004 Suzuki Verona
Dell Latitude D505 Notebook Logo
Alun Cox
