Question about BenQ Office Equipment & Supplies
Green screen on benq projector - BenQ Office Equipment & Supplies
My Projector Benq Mp620p Green Light is Blinking
Hi Ahmed, if only the green light is flashing, it means that it is powering up.
Mar 25, 2015 | BenQ Office Equipment & Supplies
Dust particles being projected onto screen with BENQ MP 525 projector
White spots on the screen are generally caused by a bad DMD chip.Multiple elements of the chip remain continuously on causing these spots.Solution is replacement of DMD chip.
Samr
Jan 14, 2013 | BenQ MP511 Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
On my projector BENQ mp511+ the green lamp keeps blinking continuously. tried shutting off the projector for a while. but no result. Please help?
I expect the lamp life is about to expire. Check your instruction book to clarify the situation.
If you haven't got one, go to the BenQ web site to down load one.
Hope this helps.
Oct 30, 2010 | BenQ MP511 Projector
Only bottom half is shown on screen from our Benq
Try lowering the resolution of your pc to a lower amount that the Projector can handle. Start as low as 800x600 and try working up from there.
To change pc's resolution: Right click on the desktop, click properties then settings and try sliding the resolution adjuster and testing each one with your projector. wait for the projector to resync itself each time.
good luck!
Dec 23, 2009 | BenQ Projector Lamp for MP610
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Aug 30, 2008 | Televison & Video
32 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
