Question about Toshiba Televison & Video
How do you get the sleep timer of thetoshiba 42wh46
The problem im having with mytv the sleep timer keeps turning off my tv all the time i have trouble to rest the settings how do i do that ?
techman
  • 3130 Answers
SOURCE: sleep
If you unplug the unit for an hour or overnight, it should go out of sleep mode. If this dosent work then its not in sleep mode and the set has a problem in the power supply or the sweep circuit. Sorry you should seek a pro to assist you in this repair. Good Luck
Posted on Jun 30, 2006
SOURCE: sleep timer
Pres Timer. Make sure the time is set. Then just set the off time. It's not really a sleep button, but it works.
Posted on Jan 28, 2008
redcrx
  • 7 Answers
SOURCE: JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Posted on Feb 06, 2008
SOURCE: Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Posted on Jul 29, 2009
SOURCE: Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Posted on Mar 06, 2010
Tv keeps shutting off
hi deborah.
not sure if this will help you out,if not go to the link at the bottom for more help.
If you don't hit a remote button for a few hours, the TV turns itself off. Check to see if there's a settings option to disable this power saving feature, or to extend the time before it automatically turns the TV off. Maybe a sleep timer setting? The sleep timer is off.
Tv keeps shutting off Google Search
Nov 06, 2017 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My tv keeps turning on and off by itself
Tv has a features for wake up timer and sleep timer. Try to check this setting maybe the time for wake up and sleep is already set to it.
May 09, 2011 | LG 26LG30 26 in. LCD TV
My rca turns on and sometimes stays on . and then turns off. how can i keep it on?
Welcome to FixYa!
Check the Sleep Timer Settings of your TV. Make sure that it does not have an entry. The Sleep Timer automatically turns the TV off at a specified time or at a specified lenght of operation.
Thank you for using FixYa. Have a great day.
Jas247
May 04, 2011 | Televison & Video
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Tv is doing my head in...
Your TV is defective. Exchanging it at the store is your only option.
May 15, 2008 | Televison & Video
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Keeps turning off
As for the 10-20 secs ,tv turns off .......I have one of those ......Im still trying to fix mine, without buying a new board ,I will post results!
Jun 09, 2007 | Sylvania 6626LCT 26 in. LCD Television
Televison & Video Logo
13 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
