Question about Amazon Kindle D00901 Wireless Ebook 3g Wifi Reader
Disassemble how do you take it apart
How to diassembly my tablet
Don't know what brand/model you have so can't tell you.Try Google - disassemble (brand/model) tablet. Unless you are installing additional memory it is not adviseable to disassemble it if you have to ask how to do so.
May 14, 2016 | Tablets & eReaders
I would like to know how to disassemble Compaq TC1100. Disassemble keyboard from screen unit.
There is a latch that you need to pull to seperate the keyboard base from the slate tablet pc. This latch is located behind the monitor where the keyboard attaches to the monitor.
Feb 26, 2011 | Compaq tc1100 Tablet PC
Hi i have a gateway laptop, im having a hard time fixing the speakers,it started wen i tried to use my speakers for my ipod.when i took the cord of my ipod out of my laptop,the laptops speakers arent...
You have possibly broken the switch, inside the units Phono Jack, this is a common thing, there is a little switch, in the Jack, that cuts OFF the Internal speakers, when used. Sometimes the ball on the end of the Plug can force the contacts too far apart and they don't make contact and cut off the internal speakers. This is a difficult fix, as the whole laptop must be disassembled, the part unsoldered, and another good part re-installed. As a cheap workarround, get an inexpensive USB soundcard, and some small external speakers. Otherwise it's off to the repair shop, or get yourself a service manual and do it yourself.
May 18, 2010 | Tablets & eReaders
Need to replace lcd screen on a Fujitsu lt c500
Below is a link to tech support chat page for Fujitsu products. The Fujitsu site does offer a user manual, however, you need a service manual. Being a customer, you should be able to order a service manual for your notebook thru fujitsu. Here is the link for the chat page:
http://solutions.us.fujitsu.com/www/support.shtml?support/support_chat
Here is the link for the user manual:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
This is a good place to start. I hope that you find this information helpful and will leave feedback to that effect if you do.
Thank You,
Brian
Jan 25, 2010 | Fujitsu Stylistic LT C-500 Tablet PC
HP Pavilion TX1320us powers up, screen is black, nothing on an external monitor - seems to be bad video card. These were recalled and after trying since May 09 with an authorized HP reseller/repair...
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Dec 02, 2009 | HP Pavilion TX1320US Tablet PC
Disassembling PDA's
I have solved my problem vith PDA's already. Simply. I opened housing of PDA's and checked connect to screen. Thank you for intrest about to solve my problem. Hi Zdenek.
Nov 03, 2009 | Compaq Tablets & eReaders
Fujistsu T4215 no POST, numlock blinks
You need to send it to Memphis, Tn for a factory reset, call the Fujitsu 800 number on there web site and have your serial number handy.
Don't disassemble a Fujitsu!! Ever!
They automatically lockup as a security precaution, aren't you glad you saved some money?
Oct 07, 2009 | Fujitsu LifeBook T4215 Tablet PC
BROKEN HINGE GATEWAY LAPTOP TB120
search "gateway e-155c lcd swivel assembly" on google or any other search engine and you will find the part that you need.
You will need to do your own replacement, but that is the part that will fix your problem
Mar 28, 2009 | Tablets & eReaders
Amazon Kindle D00901 Wireless Ebook 3g Wifi Reader Logo
14 people viewed this question
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
