Question about Kyocera Office Equipment & Supplies
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
I'm using a Kyocera 3150CI. I loaded a 10"x13" envelope into the MP Tray (to print an address), made sure to change the paper type to "envelope" in both the print settings in Microsoft Word and at the printer when asked, but the envelope comes out wrinkled. What can I do to make sure the envelopes stay smooth?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
Posted on Aug 06, 2014
SOURCE: Envelope printing
Got a 3100CN and had the same problem but found that a) Changing paper size from the web doesn't work but b) Go to the printer control panel on the printer and use the menu to set the paper size for the MPF tray for FREE. Now your application under windows will overide the whatever the printer thinks and will print. Envelope via Word all work without problem. Suggestion . Configure two printers one B&W using tray one and one colour using MPF and you can now quickly select whether to use colour or b&w. Regards John N - N2UYI/G7LTQ
Posted on Jun 02, 2007
  • 214 Answers
SOURCE: printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Posted on Jun 19, 2008
  • 3422 Answers
SOURCE: Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Posted on Aug 17, 2008
frcs68
  • 1605 Answers
SOURCE: Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Posted on Jan 29, 2009
SOURCE: Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Posted on Apr 30, 2009
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
May 14, 2014 | Kyocera Office Equipment & Supplies
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
I have a Kyocera Mita KM-4230 and I'm trying to print a #10 envelope and its asking me to use the MP tray. But it's not accepting the envelope, what do I do?
but the envelopes in the tray on the right side of the machine... open all other trays.... and attempt to print... it will ask for you to select the tray... in which case you select the mp tray... and print... now for a more permanent solution... call kyocera support and they will walk you through the proper procedures...
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Jun 23, 2009 | Kyocera FS-3900DN Laser Printer
I have a Lexmark C510, how do I print a business envelope?
You can load up to 10 envelopes in the standard tray. Try a sample of any envelopes you are
considering using with the printer before buying large quantities. See Loading envelopes in the
standard tray
for instructions on loading envelopes.
When printing on envelopes:
To achieve the best possible print quality, use only high-quality envelopes that are designed
for use in laser printers.
Set the Paper Source in the Paper Menu based on the source you are using, set the Paper
Type to Envelope, and select the correct envelope size from the operator panel, the printer
driver, or from MarkVision Professional.
For best performance, use envelopes made from 90 g/m2 (24 lb bond) paper. You can use up
to 105 g/m2 (28 lb bond) weight for the 250-sheet standard tray or 105 g/m2 (28 lb bond)
weight for envelopes as long as the cotton content is 25% or less. Envelopes with 100%
cotton content must not exceed 90 g/m2 (24 lb bond) weight.
Use only new, undamaged envelopes.
For best performance and to minimize jams, do not use envelopes that:
Have excessive curl or twist.
Are stuck together or damaged in any way.
Contain windows, holes, perforations, cutouts or embossing.
Use metal clasps, string ties, or metal folding bars.
Have an interlocking design
Have postage stamps attached
Have any exposed adhesive when the flap is in the sealed or closed position
Have nicked edges or bent corners
Have rough, cockle, or laid finishes
Use envelopes that can withstand temperatures of 170°C (338°F) without sealing, excessive
curling, wrinkling, or releasing hazardous emissions. If you have any doubts about the
envelopes you are considering using, check with the envelope supplier.
Adjust the width guide to fit the width of the envelopes.
Load only one size of envelope at a time in the tray. Envelopes may only be loaded in the
standard tray. Load them with the flap down and the flap to the left of the tray.
A combination of high humidity (over 60%) and the high printing temperatures may seal the
envelopes.
Loading envelopes in the standard tray
The recommended stack height is 10 envelopes; however, in normal environments as many as 15
envelopes may be loaded. In high temperature or humidity environments, only seven envelopes
should be loaded.
1 Pull the standard tray completely out.
2 Squeeze the length guide tabs together as shown in step 2 on page 42. Slide the guide to
the correct position for the size of envelope you are loading.
3 Squeeze the width guide tabs as shown in step 3 on page 42. Slide the width guide to the
correct position for the size of envelope you are loading. Notice the size indicators on the
bottom left of the tray.
4 Push the envelope stack aid tabs toward each other. They snap into place.
5 Flex a stack of envelopes back and forth and then straighten the edges on a level surface.
Press down the corners to flatten them.
Fan the envelopes. This prevents the edges of the envelopes from sticking together and helps
them feed properly.
6 Load envelopes flap side down with the stamp area and flap on the right. The end of the envelope with the stamp area enters the printer first.
7 Insert the standard tray.
Feb 26, 2009 | Lexmark C510 Laser Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
159 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
