Question about Garden
The soap will not pick up on my Black and Decker PW1600 power washer. the hoses are all in place and not plugged.
  • Craig Butler
    Craig Butler May 11, 2010
    Air leak, loss of suction. Maybe a light viscosity soap?
    Problem Solver:
  • 18 Answers
U need to not use the soap use the soulation un pressure use black tip
Posted on Jun 27, 2009
Where does the soap go
That varies by washer. Check the owner's manual.
If you're referring to the steam cleaner, those don't use any kind of soap or detergent.
May 07, 2014 | Black & Decker Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
The cleaning solution is not spraying out of my pressure washer.
On pressure washers with cleaning solution pick-up hoses you have to make sure you are using the black, low pressure, soap tip. If you are using the high pressure tips, red, yellow, white or green, there will be too much back pressure at the pick-up tube for it to work properly. If you are using the soap tip, check that the pick-up tube and filter are clean.
Jul 06, 2011 | Karcher Garden
I have a PW1600 Power washer. the High pressure hose connector is cracked. Can that be replaced? AND if so how do you remove it from the gun and hosing.
I don't know what brand it is, but in general the hoses can be replaced. There are fittings and hoses available. the fitting for most PW's are interchangeable. try looking at stuff here. (they do not necessarily have the best prices or stuff they just have good pictures) http://www.northerntool.com/shop/tools/category_pressure-washers+pressure-washer-accessories
Jul 05, 2011 | Black & Decker Garden
WIULL NOT PICK UP SOAP FROM CONTAINER
There could be a block in the syphon hose going from the soap reservior to the sprayer. Take the hose off and blow through it to make sure the the hose is clear. If the hose has a scrren/filter on it make sur that is clean also. Where the hose attaches to the sprayer make sure the orifice is clean and not plugger up with scum or other debri.
Mar 12, 2011 | Craftsman 3000 PSI 27 GPM Briggs ...
I need to download a Black & Decker manual for a power washer- PW 1600
This link may provide the help you need, There is a phone # that you can call on this site:
www.ereplacementparts.com/black-and-decker-pw1600-1600-psi-pressure-washer-parts-c-4167_9499_9560.htm
I wasn't able to find it.They may know where to link you to to get a download of your manual. I wasn't able to find it.
Jim
Sep 23, 2010 | Garden
The air compressor attachment broke. Is there a
I purchased a replacement part (air chuck) at Wal*Mart. Lubricate the end with soap so it will slide inside the hose and then secure it with a small hose clamp. And, as previously stated. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
Mar 07, 2010 | Vector 1 Million Power Series Spotlight &...
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
Cord is rapidly "minced" up
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
Jul 09, 2009 | Black & Decker String Trimmer Cordless 12"...
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
Garden Logo
404 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
