Dstv decoder dsd 990 ddd error not flashing its the power supply there is someting that I can take out or bridge it to get it 2 work
5 Suggested Answers
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
RALilja
  • 381 Answers
SOURCE: What can be the problem if my Dstv decoder model DSD 1131 doesn't have signal strengh or signal quality I'm staying in Pretoria how can I fix the problem
The best that I can give you is at this link:
http://hopeafrica.tv/index.php/component/content/article/40-schedules/202-dstv .
It should be noted that Africa does not have digital tv so you should probably hook an antenna to the tv without the box and have the tv search for analog tv stations as that will stand the best chance of picking up what few channels they do have.
Good Luck!
Rich Lilja
Posted on Jun 12, 2015
gopakumarg43
  • 74223 Answers
SOURCE: MY dstv DSDD 1132 decoder is flashing red and green lights but yellow light is steady. tv is black and remote not responding
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 12, 2017
How do I clear error BEi or BE1 on dual view dstv decoder.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/..
Aug 17, 2016 | Televison & Video
Good Luck!
Rich Lilja
Jun 12, 2015 | Televison & Video
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
Decoder muitichoice d5d 990 flashes ddd does not respond to remote shows no pictures on television
1) replace old batteries put a new ones, but you must clean and tight the spring contacts batteries from dirty, corrosion, oxide, use contacts cleaner.
2) opent the r.control and clean the keypads from dirty, oxide,corrosion, with c. c. and try again. the LED must be ON when you hit any key. use the digital or cell phone for to view. see the diagram attached.
Nov 05, 2013 | Televison & Video
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Dsd 933 remote not working
Thunderstorm do not affect the remote control. It might have effected to your TV. Infrared sensor section circuit inside the TV should be checked.
Feb 09, 2013 | Televison & Video
Dstv decoder dsd 1131 is just flicking when put on power.cause of problem is that water dropped on mother-board.there was carbon but i brushed it with methylated spirit.but is still flicking and does not...
In most cases if there was water and the set was put on before the traces were removed , it is quite possible that some sensitive component could be damaged.
hence it is important to start from the beginning. Use a hair dryer to warm, use soldering iron to solder suspected joints and if you hear/see steam while the iron is used on the pins then it is for sure that water is lodged in the component base. You will need to do the work with caution till there are no traces. A slight short can result in flickering , if not there are failures in the board.
check this link for some tips;
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Apr 12, 2011 | Televison & Video
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
