Question about GE ZDW24A Wine Cooler
Ice build up inside machine
How do I fix it
I have a Sears Kenmore model 106.5002 refrigerator. The ice machine keeps building up blocks of ice. We have melted it with a blow dryer. It works and dispenses ice.
Suggest turning the ice maker off by elevating the shutoff lever arm. If ice continues to build after a few days the solenoid water valve is leaking and needs to be replaced.
If no ice build up it is likely that the fill tube is dirty and water is freezing in the tube disrupting the normal tray fill process.
26375967-eslp3us1ub1u3afrhtff0zvp-3-5.jpg Hope this helps?
Nov 28, 2016 | Kenmore Refrigerators
How do I clean this machine?
you don't give a lot of information.
Outside with detergent and warm water. Stains with something like Comet.
Inside, if you have ice build up, switch the freezer off. Fill a bucket with hot water, and place inside for an hour. The ice build up will come off with a plastic scraper. DON'T use a knife! Wash down with soap and water, switch back on and leave an hour to get to temperature.
Aug 12, 2015 | Freezers
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
WHY IS ICE BUILDING IN THE AREA WHERE ICE EXITS MACHINE (BOTTOM) & INSIDE DOOR EXIT? THEREFORE, INTERFERING OPENING THE DOOR. I HAVE REMOVED SEVERAL TIMES & IT HAPPENS AGAIN?
this ice is coming from the air after you open the door of your ref.the cold air goes down and the hot air enter to your ref. the hot air is highly on humidity that cause of building of an ice. try to fix your door maybe the doorgasket isnot align that has leakage of cold air on your ref . avoid too much door openings. or try to defrost your ref. weekly.
Feb 13, 2011 | KitchenAid Refrigerators
Ice maker is not working
ok one of the first steps is to make sure your getting water inside the ice maker feel with one of your fingers if you can feel ice or water on the inside of the tray if you have ice then you would have to disconect and remove the ice maker fromthe machine and run hot water to clean out the ice build up on the inside then reinstall the ice maker back into the machine and test for 24 hrs to see if you get ice if you dont then you have to replace the icemaker. If you do not have any water going into the icemaker water tray then you would have to check the water valve located in the rear of your machine if the water valve is not bringing water to the icemaker replace the water valve hope this helps
Jul 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Nov 04, 2008 | Zanussi Z57 / 3 Bottom Freezer...
GE ZDW24A Wine Cooler Logo
82 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Day Coker
Are you a GE Furniture Expert? Answer questions, earn points and help others
