Question about Dacor CM24P-1 Coffee Maker
My built in dacor coffee maker drips water out of steam port how do i stop it
3 Suggested Answers
SOURCE: Dacor coffee maker
Welcome to the club of unhappy Dacor coffee machine owners. The problem you are having is the problem everyone has had. The only thing I can suggest that has worked most often for me is not leaving the machine on for very long. I think the temperature gets messed up if it is left on too long. I just use mine now for a few cups in the am and then I turn it off. I've been so frustrated with it that I have gone back to my french press. One of the posters on this site actually got Dacor to buy her machine back. I will probably try that route as well.She replaced it with a Meile and is very happy with it. Good luck!
Posted on Aug 09, 2008
baraquielnar
  • 247 Answers
SOURCE: I have a Dacor CM24T coffee maker. The on/off
try to disconnect the switch and connect or splice the wire directly then plug on the unit if the machines runs it means only the switch damage replace it a new one. or after replacing the swicth the trouble is persist you call a technician.
Posted on Mar 14, 2011
Continuous steam coming out of my cappuccino machine
I have a Dacor Coffee System/ Built in...when i turn on the CN12- check steam temp. and steam comes out. how do i fix this?
Rick
Aug 18, 2013 | Dacor CM24P-1 Coffee Maker
Have an ace lp that drips even when turned off and fills pot to overflowing any suggestions on correcting problem
Hi. you have a solenoid that has got a piece of lime scale stopping it from completely closing, You can try doing a Descale cycle which should flush it out. If its a plumbed in model, its hard to stop the leak with the mains water pressure, otherwise drain the steam out, when you turn off the machine. The steam pressure if left in the machine, can keep it dripping. Darryn REPAIRER
Sep 23, 2011 | Newco ACE-LP Coffee Maker
When system is turned on Steam immediately begins to come out and error code CN12 appears
Hello, i have the same problem...did you get the answer on how to fix this CN12 error/ steam coming out on your Dacor Coffee system? RickPulsinelli@gmail.com
Feb 15, 2011 | Dacor CM24P-1 Coffee Maker
Very little water is dripping into the carafe
Try to run vinegar undiluted through the coffee maker first. If this does not help, you may have a plugged valve in the coffee maker or a tube/hole where the coffee maker water should drip through. if this coffee maker has a dispenser(where you put your cup against it and the coffee comes out) then there is likely a plugged up valve. This will require dismantling the coffee maker to clean it. Usually coffee makers get plugged up because coffee leaves a residue that requires scrubbing at time to remove.
May 26, 2010 | Dualit Expresso + Filter Espresso & Coffee...
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Water is dripping out above ,between coffee and
The steam valve housing is probly broken or leaking the line for it runs under the button panal
Dec 15, 2009 | Saeco Vienna Deluxe
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Dec 21, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee maker problems
Try cleaning the area where the switch is for the pot removal.
It is a feature so that you can take the pot out from the coffee maker and it is not suppose to dripped whil doing so.
It maybe that the switch for that function is not working right.
Feb 15, 2008 | DeLonghi DC55TCB Coffee Maker
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Dacor CM24P-1 Coffee Maker Logo
Top Dacor Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Michael Vincent Cruz
Tom Chichester
Are you a Dacor Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
