Question about ViewSonic G90fb 19" CRT Monitor
'memory recall ok' displayed always on the screen. Does not go even if selected yes or no. Why?
  • 1 more comment
  • kev18284 Dec 11, 2007
    ya im having the same problem "memory recall ok?"
  • jackowacko May 10, 2008
    I have the problem of "MEMEORY RECALL OK?" popup when i start the system on my Viewsonic G90fB series monitor and reappears every minute
  • pradeep501 Aug 31, 2008
    same problem
I got the problem solved. The other day i called up the viewsonic tech support, service engineer visited and changed the switches inside. the problem got solved. So call up the tech support of view sonic at (india)
We need the following details to create an RMA Request for your Product.
Once an RMA request is created our service Engineer will contact you within 2 Business Days to attend the call.
1.Customer Name
2.Phone no with STD code
3.Complete Address
4.Model and Serial No of Product
5.Description of problem
We can be reached on this email address or through phone on our Toll free No1800-11-9999 or Toll No:-011-26990006
Have a Great Day Ahead.
Thanks & Regards
ViewSonic India Technical Support
bye
Posted on Sep 26, 2008
I had posted my problems on 10th May and 6th Jul, about 20 days ago i contacted "Viewsonic", my monitor was under 3 Years Warranty, their Technician came home, and told me there was a problem the switch panel and he replaced all the switches (mind you he used a solder rod to do that).
Now the problem has gone away.
Do no try any tricks just get in touch with you Viewsonic vendor, they will send their Technical guy who will solve it for you, you may have to pay.
I had written earlier (June 23, 2008) that i had formatted my harddisk and reinstalled window, the problem of "Memory Recall OK" had disppeared, but now after 15-18 day the problem has resurfaced with bizzare results.
Initially i used to get "Memory Recall OK", next day that stopped, i started getting the main menu which would disappear after a few seconds, then 2 day later i started get another type of popup message "OSD LOCKEDUP", now 2 days later the results are even more bizzare, the Brightness/Contrast menu pops up and can you beleive this, its reduces the intensity of the monitor (gradually) as if some person is doing so.
I had mentioned earlier that there maybe a Virus, now i take back my words. I can safely say there is no Virus, there might be GHOST.
Posted on Jul 06, 2008
Thanks for the detailed explaination on how to solve the issue.
Fact is, i Formatted the Windows Partition and reinstalled the Operating System (for reason other then this) and the issue seems to have disappeared for good. Your guess is as good as mine.
Was it a Virus???.
Posted on Jun 23, 2008
From the Users Manual for this monitor:
"Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting."
When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2.
If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that.
It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck.
Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife.
If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty.
One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Hope that helps solve your problem...
Posted on Jun 22, 2008
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
I have a canon pima mx340 printer/fax machine. How do you get a stored fx to print out
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Nov 08, 2010 | Canon PIXMA MX340 Wireless Office...
How do you do a master reset touch screen is not working
Perform a Master Reset
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Reset Setting.
  4. Scroll to and select Reset Default.
  5. Scroll to and select Yes.
  6. Enter Security code, press OK.
    NOTE: The default security code is 0000.
Reset Memory
  4. Scroll to and select Clear Memory.
  5. Scroll to and select desired option:
    • Handset Contents
    • Handset Personal info.
    • Memory Card
  6. Scroll to and select Yes.
  7. Enter Security code, press OK.
May 14, 2010 | LG Xenon GR500 Cell Phone
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
MEMORY RECALL OK?
Feb 09, 2008 | ViewSonic E70f 17" CRT Monitor
Moniter problem
Sep 16, 2007 | Computers & Internet
MEMORY RECALL OK? problem mine is view sonic monitor .from the past one month its showing problems in display.its giving "MEMORY RECALL OK?" and this whether i press any of the two buttons asked for ,is...
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Aug 03, 2007 | ViewSonic E70b 17" CRT Monitor
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Memory recall
Oct 31, 2006 | ViewSonic E70 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
ViewSonic G90fb 19" CRT Monitor Logo
1,269 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
