0xc0000185 windows8 acer e1-570 will not start up
Windows & will not start. Status 0xc0000185
Your laptop cannot communicate with the hdd.
Try the link.
Windows 8 Error Code 0xc0000185
Apr 25, 2016 | Computers & Internet
0xc000185 error
How to fix The Specific Code Is 0xc0000185 errors? There are several methods of fixing The Specific Code Is 0xc0000185 errors. You may need to try more than one method before you're successful.
Download the (The Specific Error Code Is 0xc0000185) repair tool. avg-linkscanner-verisign-safe.jpg Install the program and click on the Scan button. Fix any errors it finds once the scan is complete. Restart your computer.
• Manually edit your Windows registry. Start the registry dditor by clicking the Start button, typing regedit in the Search box, and pressing Enter. Open the HKEY_LOCAL_MACHINE folder ==> "Software" folder ==> "Microsoft" folder==> "Windows" folder ==> "Currentversion" folder. Click on the Run folder ==> Click on the The Specific Error Code Is 0xc0000185 file. Delete the file by pressing Delete The Specific Error Code Is 0xc0000185 key. You can then reinstall the file on your PC
• Update the drivers for the device. It's possible that installing the latest drivers for the device could correct the error. If this works, it means that the existing drivers you reinstalled in the step above may well have been damaged.
• You can also download the Windows The Specific Error Code Is 0xc0000185 recovery utility which has proven successful at fixing this error..
Feb 17, 2014 | Samsung Computers & Internet
Error 0xc0000185
A 0xc0000185 error is usally a regestry error and there are two possible fixs, 1 is to reinstal windows or if you have a system reserve partiton you can resore windows with that both of these may and proberbly will lead to data loss, 2 is you can use a registry repairing program such as CCleaner to repair the registry,
Good luck ;)
Oct 19, 2013 | Acer Aspire 5315 Notebook
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
O error 0xc0000185
This error can occur when there is a problem in reading and/or verifying data on the HDD/SDD. The most common cause is a loose data connection, although the power connection can cause similar issues. Check the connections at both ends of the cables. Also check the connections to your optical drive and make sure that your RAM is correctly seated. Since you have already opened your laptop to do prior maintenance, it is quite possible that you have dislodged one or more cables without realising it. By the sounds of it, your laptop continued to work for a short while before failing again with your current issue. It is likely that a sudden sharp knock might have caused a loose connection to become disconnected.
Apr 23, 2013 | Acer Computers & Internet
My acer 5920 hhas suddenly stopped working, it is showing the error code 0x000000ED (0x867A52D0, 0xC0000185, 0x00000000, 0x00000000) Help!
STOP 0x000000ED UNMOUNTABLE_BOOT_VOLUME - this is issued when the data on the hard disk is completely corrupted.
Reinstall Windows and if the problem returns very quickly then the hard disk itself is dying - you will have to replace it and reinstall one more time.
Apr 24, 2011 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
