Question about Whirlpool RBS305PDS Electric Single Oven
F2 shows on display on whirlpool gas stove - Whirlpool RBS305PDS Electric Single Oven
    Master:
  • Whirlpool Master
  • 480 Answers
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
Posted on Jan 10, 2015
3 Suggested Answers
  • 327 Answers
SOURCE: oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
Posted on Jun 02, 2010
  • 417 Answers
SOURCE: My whirlpool gas stove displays a message F4-E1
F4-E1 is meat probe malfunction. Check the probe over and remove it see if that clears it.
Posted on Dec 18, 2010
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
I have a whirlpool stove that is gas the display won t work so cannot use oven.
It's likely that the board on which the display is found also contains the control electronics for the oven functions.
If you want to look into replacing this yourself, go to the link below for illustrations of your unit but the page lists several variations beyond the model number you listed so check your literature from your unit to establish which exact unit you have:
Whirlpool range
Sep 16, 2011 | Whirlpool SB160PEE Gas Single Oven
My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
To lock/unlock the controls: Turn all surface burners off.
Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
Feb 11, 2011 | Whirlpool Ovens
Oven won't heat, display out, gas burners on stove
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
E6 F2 problem
We repair a lot of control boards for this problem.
Best Regards,
Bruce
www.fixyourboard.com
May 10, 2010 | Whirlpool GBS277PRS Stainless Steel...
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
Gas stove works, but oven does not
yes replace the ignitor, this is the most common failures of ovens not coming on.
Dec 10, 2007 | Whirlpool SB160PEE Gas Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
83 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
