Question about Price Pfister 042-YP0E Ashfield Single Handle 4-Inch Lavatory Faucet with P
How do I take apart a pfister ashfield sgl handle spigot to check water flow?
It has a slow flow on either hot or cold. Does it have a screen and if so, how do we access it?
jgwhomeequip
  • 1902 Answers
SOURCE: Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Posted on Feb 13, 2009
  • 54 Answers
SOURCE: Problem with Price Pfister Savannah Two-Handle
Sounds like there is loose solder in the supply pipes. You would have to disconnect the flexs and blow it out.
Posted on Sep 14, 2009
  • 41 Answers
SOURCE: New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
check if any valves are not fully open first. if its a replacement of one that was working fine then the taps are most likely duff
Posted on Mar 03, 2010
SOURCE: re: single handle lav. Ashfield: cold water flow
I have the same problem with my Ashfield faucet.
I am going to contact Price Pfister and try to get a new 'cartridge'.
On another note, my Ashfield towel rings are also broken. The connection where the two pieces meet is so weak it cannot handle daily use. I am going to bring this up with Pfister as well.
It doesn't seem like Price Pfister has very good products.
Posted on Jan 05, 2011
packrat1948
  • 528 Answers
SOURCE: hot water side of a 42 ashfield faucet allows very
You will need to take the faucet apart and clean it out. If the faucet is a few years old I would just replace the cartridges and be done with it.
When the water heater was replaced the lime build up in the piping was dislodged and I bet the faucet you are having a problem with was the first faucet used after the new water heater was installed.
Posted on Mar 04, 2011
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
Aug 29, 2014 | Pfister F-529-MYPS Ashfield Pullout Spray...
The hot water side of my 42 ashfield faucet does not flow. It is only 2 years old and I clearly remember having more than a trickle of hot water. How do I repair this. The hot water valve under the sink...
How are the other faucets in house working hot water wise .. often the 3/4 nipple plug's up just as it comes out of water heater . if other faucets OK the i have found the clog in the stop / valve feeding the hot side shut off water to house or shut off hot water at heater pull your stop & check it out ..if problem emanates from water heater replace or take screw driver & **** out nipple.. at w/h ..
Apr 04, 2011 | Price Pfister 42-YP0E Ashfield Single...
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
Hot water side of a 42 ashfield faucet allows very little water flow. I think it is stopped up, It stop when I change a hot water heater
Mar 04, 2011 | Price Pfister 042-YP0E Ashfield Single...
Re: single handle lav. Ashfield: cold water flow is fine; hot water flow severly restricted. Have disconnected supply tube and flow is fine into a bucket so it is not a problem with valve or supply...
Dec 31, 2010 | Price Pfister Ashfield Single Control...
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
Feb 13, 2009 | Price Pfister Ashfield Single Control...
No cold water from bathtub fixture/Shower won't engage
If you put on the cold and Nothing at all comes out, check the water supply valve to the tub. If it comes out alittle ...the washer probiblly came off and is stuck you will have to remove the valve ,but 1st check that the handle is not stripped ,and that is actually moving the valve to the open position Turn the handle and see if the handle backs out ,like its trying to open.
Please rember to leave me some positive feedback if Ive been Helpful! Thanks !
Dec 15, 2008 | Price Pfister Ashfield Single Control...
Price Pfister 042-YP0E Ashfield Single Handle 4-Inch Lavatory Faucet with P Logo
53 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
