Question about Samsung Galaxy Exhilarate SGH-I577 AT&T
Disconnected battery error when charging - Samsung Galaxy Exhilarate SGH-I577 AT&T
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Connect the charger pin correctly..
Posted on Sep 02, 2014
Wont star put new battery in
If it ISN'T cranking over ok ... and has a discharged battery..
Disconnect the leads from the rear of the alternator. A faulty alternator can discharge a battery within minutes. Charge the battery and leave the alternator disconnected. Try and start the car.
If - with a charged battery and alternator disconnected - the engine seems very slow to crank or makes a 'clicking' noise ... try cleaning the battery terminals - particularly where the black lead connects to the engine block/bodywork.
Check the leads -and terminals - for breakage/corrosion. A 'bad earth' or corroded/loose battery terminal can cause non-starting problems.
If all is ok and the car spins the engine but won't start, suspect a sensor fault.
Don't waste money on replacing part after part in the hope that the care will fire up. The best - and cheapest - option is to have an OBD - a hand held diagnostic check done. This will identify any error codes and tell you the cause .. i.e 'crankshaft sensor fault'.
May 04, 2016 | Cars & Trucks
Battery died. Got it jumped. Why is VSC light flashing,check engine light is on, and gas pedal doesn't respond?
Borrow a battery charger. Disconnect the battery and fully charge it. Reconnect to a fully charged battery. This should reset the ECM. If not you need and engine code reader to check the error codes.
If you Google 'VSC light flashing' there are lots of Toyota owners who have had the same problems.
Dec 25, 2015 | Cars & Trucks
Charging woes
The replacement power pack could be defective.
Sep 21, 2017 | Video Cameras
Uniden battery will not charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 04, 2012 | Uniden Cordless Phone
I have 2003 Lincoln LS. I left my lights on and I think I killed the battery. Because when I tried to start the engine it barely turned over. So I setup the trickle charger and let it charge for like 3...
2 things come to mind. first a trickle charg will take about 8 to 10 hours to fully charge the battery, so you might need to charge it longer to see if the battery takes a full charge. did you try jumping the car with another.
second is it possible the charger was hooked up backwards (pos to neg and vice versa)
Jan 16, 2011 | 2002 Lincoln LS
92 yj gauge show not charging disconnect battery engine dies but check with meter shows charging if you disconnect the battery should it keep running if its charging.
It is NOT good to disconnect the battery with the engine running as you could destroy the computer!!
Charge volts with digital multi meter shouild be 13.8v-14.4v...if low then battery must be fully charged to check charge rate.
Mar 10, 2010 | 1992 Jeep Wrangler
Battery drained, low engine power light on, engine light on
battery likely not holding strenght, light will stay on as a reminder of the problem, disconnect the negative cable of the battery for 5 minutes and reconnect it, this reset the error codes ( that is what the light is, an error code), good luck
Jun 02, 2009 | 1999 Chevrolet Corvette
Battery Charging Error - Disconnect Now error message
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
9120 battery failure
sometimes the battery tester is not enough to check the battery. battery also prone to tear and wear.because of charging ang discharging. replace the battery
Feb 05, 2008 | Powerware 9120 UPS System
Samsung Galaxy Exhilarate SGH-I577 AT&T Logo
75 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
