Question about Hotpoint Aquarius WF000 Front Load Washer
I think there is a blockage in the machine,but can't find the filter the machine is a hotpoint aquarius extra wma33 which is not listed below
  • gillbutler_1 Jun 23, 2009
    Thanks for that information, but how do I get to it? usually there is a plug thing right at the bottom of the housing on the front of the machine.
  • 57 Answers
It is underneath the washer attached to bottom of drum
Posted on Jun 23, 2009
  • 47 Answers
I have seen socks get stuck in the pump, They are usually clear plastic so you can look into them. look for the discharge hose attached to the pump to aid it.
Posted on Jun 25, 2009
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Extra WMA40 - Prewash light flashing and cycle not completing? The water level also looks to be very high? As tenants this machine has been installed (we suspect second hand) to replace a...
The water level on the Hotpoint WMA range of machine should be below the door, check out the error code definition at this site. You probably have a pressure chamber blockage or partial blockage. There are also workshop manuals for the Hotpoint WMA & WM machines which run through this sort of repair.
Mar 20, 2010 | Hotpoint WMA40 Front Load Washer
I have a Hotpoint Aquarius 1100 washer dryer and think the filter might be blocked but I cannot locate the filter to check it. Any ideas?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plasic filter inside hose..
Also check the pump for a blockage as well.
Thisn should solve your problem.
Dec 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 28, 2009 | Washing Machines
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Invalid friend needs User Manual for his Hotpoint 1300 Aquarius Extra WMA33. Can you please help>
Hello.I can help with your request.
In the browser bar type in-
hotpoint user manuals
In the drop down list on the left click on
manuals-user guides-handbooks-hotpoint service
In the search box, enter the model number of washer, and down load the instructions.
Please leave a fixya rating for my solution .
Thankyou.
Jan 30, 2009 | Washing Machines
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Where's the filter?
all hotpoints are the same only filter that they have is uneath in the pipe that comes out from the middle of the outer drum undo clip having a tub to catch any water that comes out tip the pipe up and pull clear plastic filter out the only one that there is m8
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
308 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
