Question about Samsung CLX 3160fn All-In-One Printer
Factory reset password for samsung c9250nd - Samsung CLX 3160fn All-In-One Printer
2 Suggested Answers
mobil master
  • 14641 Answers
SOURCE: reset password on Samsung a797
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Aug 02, 2012
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
How can i find id , and password for samsung account? i have forgotton it
Click on the forgotten ID or password link from this samsung account website and reset your details.
Services Samsung Account
May 09, 2016 | Samsung Galaxy Grand Prime G530 Factory...
How do I reset my password on my samsung tablet?
The best way is to do a factory reset and you'll be able to set your own new password.
Jan 11, 2014 | Samsung Apple Ipad 2 64gb, Wi-fi 3g at&t,...
Full reset samsung slate 7
want to bring it back to factory settings
Nov 19, 2012 | Samsung Series 7 11.6" Slate Tablet
I have a samsung jet..keeps going off on its own and poor signal.samsung said restore factory settings but then asks for password.i never did set up password.please advise
The FULL RESET CODE is *2767*3855#. This resets your mobile immediatly and sets it back to factory settings. PIN 0000 PASSWORD 00000000.
May 14, 2010 | Samsung Jet S8000 Cell Phone
I samsung highlight t749 security passcode reset
easiest way is to open up your dialer and type the following code: *2767*3855#
If you get the unlock password screen at boot up, try hitting the SOS in the bottom left, if it brings up the dial screen then type it in. It will reset the phone to factory settings and reset the password to 0000. You can then confirm this worked by going into menu/settings/reset settings/master reset. Then type in 0000 when prompted and again to verify. If your phone resets again then you know your password has been reset to factory default.
Dec 25, 2009 | Samsung Highlight Cell Phone
Samsung CLX 3160fn All-In-One Printer Logo
207 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
