Question about Konica Minolta magicolor 2300DL Laser Printer
Not printing the same color from computer monitor different colors and small white line just on the right side
McCuskerCo
  • 8 Answers
SOURCE: Color Printing Produces Pink Horizontal Lines
Hello we have had customers with this problem and this model printer We came upon this type of problem also exhibited the same lining when you did a nozzle check independant of the computer (not attached to computer and just using the internal head check print) This was a cartridge problem and after replacing the cartridge the problem stopped.
Posted on Jun 25, 2007
  • 214 Answers
SOURCE: No longer prints in color
check that the cartridges is installed correctly, print demo page prom printer. if its B/W choose quality in menu and color mode there you can switch B/W and color printing
Posted on Jun 19, 2008
Arius
  • 446 Answers
SOURCE: color lines on edge
if you can tell me what color i would probably assume it is coming from either:
1- Fusing Unit ( probably dirt on the rollers)
2- Either on the 4 colors M, C, Y, K (proably cleaning assy failure)
if all prints have the same problem and the color of the lines appear darkinh or grayish, it could probaly cause by cleaning prob.
Posted on Aug 26, 2008
  • 214 Answers
SOURCE: magicolor 2430 DL vertical lines.
pleas take a closer look at the pc drum and transfer belt, if there are also stripes then you find a problem, stripes on pc drum means new pc drum and on TBU there is possible to clean the cleaning unit but not in every case. if cleaning doesnt help new TBU
Posted on Sep 17, 2008
Corysf62
  • 188 Answers
SOURCE: Dell 3100 CN fades on right side of page only
This is caused by one of two things.
1) One of the handles on the toner cartridges is not seated all the way down. 90% of the time, this is the problem, and of that, most of the time it is the cyan cartridge that is not seated properly.
2) there is toner covering part of the print head. Sometimes this is just a temporary problem that can be fixed by simply cleaning the printhead lens with the cleaning wand. ( i will explain that in a moment). If cleaning the printhead works, but then the problem reappears shortly afterwards, then you have a more serious problem in that the developer housing for one of the toners is defective and leaking onto the printhead. When cleaning the printhead, make note of the most prominent color on the cleaning wand pad, as this is probably the defective housing's color.
To clean the print head
a) Open the front cover.
b) on the right hand side, slide the lite blue handle forward. This will open the access hole for the cleaning wand on the right hand side of the printer.
c) pull the cleaning wand out ALL OF THE WAY until it comes to a stop. Then slide the wand back in ALL THE WAY until it can not go in any further.
Repeat step "c" several times.
DO NOT move the wand back and forth unless you pull it all the way out and all the way back in. This will only smear the toner back and forth across the print head. when it is pulled all the way out it hits a lift that will lift it up and over the print head on the way back so it does not move backwards across the printhead.
the fuser is fine, and one of the two solutions above will fix your problem.
as I said though, if the problem is quick to return, then one of the developer housings are leaking.
Posted on Nov 17, 2008
Bizhub c250 print job are blank Printers & Copiers
DOES The Meter count form come out blank when you. print it? Does the Test print come out ok in the user setting print form select test print. Is it OK? Go to service mode select each color and print are they OK does the machine COPY OK in color or black and white? Try different computer try different files try adobe try web page try outlook excel etc. mite just be that file try different file same program. Can bad drums or transfer belt or transfer roller the sponge looking roller right side when open.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 14, 2014 | Konica Minolta bizhub Office Equipment &...
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Can I use a black and white cartridge on the color side
No. The electrical connection are different in the print heads.
Apr 17, 2013 | HP Deskjet 6980 InkJet Printer
Three small white vertical lines in black printwhere the black does not print. Not present in other colors.
This is coming from the Black Drum Unit. You may be able to remove the unit and look into the slot on the top. You should see the drum which is green in color and may be able to see the lines. Not much you can do with these units so you may just have to replace it.
Jan 16, 2010 | Ricoh Aficio CL2000N Laser Printer
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Oct 26, 2009 | LG L1920P 19" LCD Monitor
How to print in black and white only
Goto Control Panel > Printer and Faxes > Right Click > Printer Prefernces
(on your desired Printer)
A dialogue box will appear, now from here every printer got a bit different tabs.
Even though its too easy to find somthing like "color".
Under such tab you will find options like
  • Color Printing
  • Gray Scale
  • Black Ink Only
  • Toner Saver mode (For Lasers)
So select the Black & White option, and its done.
Do Rate Me!, If helpful.
Jul 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Nov 10, 2007 | Lexmark C510 Laser Printer
Dual-Monitor Color Difference
The solution to this one is simple. Goto to the monitor that does not match and match it through the front panel settings. Also I would check to see if both are set exactly alike in the windows hardware settings.
Sep 19, 2007 | ViewSonic VA1930WM LCD Monitor
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
