Question about Sport & Outdoor - Others
How do you adjust height of kettler parasol - Sport & Outdoor - Others
I need a manual for kettler traveler
Touring Bikes Buy Commuter Bicycles Touring Bicycles More KETTLER USA Kettler USA online shopping for tricycles pedal tractors ellipticals... , Kettler USA online shopping for tricycles pedal tractors ellipticals... ,,If you are unable to find your product manual please contact KETTLER Parts:
Phone: 866.804.0440 Monday thru Friday 9:00 a.m. to 4:30 p.m. EST Fax: 757.563.9273 email: parts@kettlerusa.com
Mar 09, 2015 | Kettler Sport & Outdoor - Others
Need to find a PARASOL Gateway Trellis Indoor Outdoor tan curtain panel size 96L X any width
Try this: http://www.bizrate.com/outdoor-decor-gazebo-stripe-grommet-4047657535/shop
Mar 03, 2013 | PARASOL Gateway Trellis Indoor Outdoor...
Error 51 Treadmill Kettler Track Performance
this a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have a Kettler Condor Elliptical and when I use it I am getting a squeeking sound from around the wheel area (like a belt is misaligned??). Any ideas? I am afraid of taking anything apart, so at this...
Do you still have your manual? I kind of remember running into this, I think it was something simple( sorry I can't recall!) like lubrication or uneven alignment (fixed by adjusting the feet). I don't see the condor on the kettler USA site, but they still may be able to help.
Feb 02, 2011 | Kettler Exercise & Fitness
I am having problems with the tension adjuster on Kettler favorit on the left arm. Every time I adjust the tension to increase it, the tension grip slips back to the original lower position so I get an...
The tension adjusting mechanism in all intensive purposes has worn out and will need to be replaced. Since I don't know where it was purchased either in USA , Canada or the U.K.
aftersales@kettler.co.uk
Tel: 01527 591901
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:info@kettlerusa.com
KETTLER® CANADA PO BOX 171 HASTINGS, ON K0L 1Y0 CANADA
Phone # 613.475.3300 Fax# 613.475.3395 e:mail:murray@kettlercanada.com
Jun 12, 2010 | Kettler Favorit Rower
Where or/and how I add the umbrella into my Bugaboo Cameleon?
Hi
The parasol fits onto the foam surround that you attach the seat/carrycot fabric onto, unless you have the two clip parasol which can be attached to the handle.
Hope this helps.
Mar 22, 2010 | Bugaboo Cameleon Jogger
Parasol to fit quinny freestyle xl carrycot
Hi yes they will but you will need to buy the clip for the quinny they sell them on ebay this allows you to use most parasols
May 16, 2009 | Quinny Freestyle 3 XL Stroller
Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
May 06, 2009 | Kettler Coach Rowing Machine
How to attatch parasol
You can attach the parasol to the front bar or to the sides of the seat frame. You would attach it like you would attach the cup holder or the canopy clamps.
Jun 25, 2008 | Bugaboo Frog - Aubergine Stroller
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
