Question about Suunto Cobra Integrated Computer
Pressure gauge problem suunto observer
My watch shows an altitude of 28156 feet at the setting of 1013 hPa on the barometer setting - I can't get the right altitude. Also the temperature is showing as 225f which is clearly wrong. How do I fix this please?
4 Suggested Answers
  • 16 Answers
SOURCE: Pressure gauge problem with Suunto Cobra 2
Salva,
The error in pressure is actually a "feature" of Suunto computers. Suunto is probably one of the most conservative brands out there, and many experienced divers tend to stay away from them for that very reason.
The manual actually calls out this "feature" on page 27.
The remaining air time calculation includes a 35 bar/500 psi safety reserve. This means
that when the instrument shows the air time to be zero, there is still about 35 bar/500 psi
of pressure left in your cylinder, depending on your air consumption rate.
http://media.suunto.com/media/suunto/manuals/en_US/cobra2_usersguide_en_v3_m56577569830698583.pdf
Regards,
Darlene
Posted on Jul 31, 2009
  • 16 Answers
SOURCE: Depth and time not correct
Do you live somewhere significantly above sea level?
If not, check your personal altitude setting. It's explained on pages 20 and 23 of the manual.
SOURCE: Suunto Cobra Computer Console, battery replacement
Hey scuba2man, I have the same problem. Did you ever work out what was going on? My console didn't register any depth for first couple of dives (I had to turn it on every 5 mins to check air). Next couple of dives it told me I was between 98 and 103 metres deep (whatever that is in feet). I was at a maximum depth of 22m!!
I will let you know if I find solution. If not then I'll just get a new one!!!
Posted on Jan 05, 2010
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
How to fix the error concerning barometer
1 atm = 29.92 in Hg (inches of mercury)
1 atm = 760 mm Hg (millimeters of mercury)
1 atm = 1013.20 millibars
1 atm = 14.7 psi (pounds force per square inch)
1 atm = 1013.20 hPa (hectopascals) ...
Unit Number Required Data Entry Elevation Of Barometer ASL Meters Feet Observed Barometer Reading Inches Hg Millibars
Nov 04, 2016 | The Watches
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
Locked screen , need button combo for suunto core
If you enter the following into your search engine, you will see a list of instruction manuals.
www.suunto.com/en/Support/Download-Center--User-Guides/
Download the one for your watch.
Feb 18, 2010 | Suunto Core Wrist Top Computer with...
I would like to hnow how to set my taylor barometer, my elevation is 850ft, but there is a small screw at the back that has to be set, could you help me?
Atmospheric pressure will vary day by day even though you know your altitude. Call your local weather station and ask for the current pressure. Then set the same pressure on your barometer. If theyare at a different allitude to you but within the same pressure area, you will have to calculate the press. diff for your altitude diff.
Feb 12, 2010 | Boating
Salva,
Regards,
Darlene
Jul 30, 2009 | Suunto Cobra Integrated Computer
Jun 15, 2009 | Suunto Cobra Integrated Computer
Altimeter setting creeps up on Suunto Vector
It sounds like IC (integrated Circuit) in your watch is mulfunctioning, but can be something else. Can't say without inspection.None of the readings mentioned by you is acceptable.
As the watch is purely microelectronic, there is nothing you can do but to take it back to the retailer and ask for repair or replacement. If your watch is just 10 days old, this must be done under warranty and at no cost to you.
Don't forget to rate, please.
Jan 05, 2009 | Suunto Vector Wristwatch
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Suunto Cobra Integrated Computer Logo
370 people viewed this question
Top Suunto Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Suunto Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
