Question about Garden
How to fit a grass flap on a mountfield princess 14
2 Suggested Answers
  • 111 Answers
SOURCE: how do i replace blade on mountfield princess lawn
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Posted on Mar 30, 2011
Testimonial: "Thank you for your help it was much appreciated, did the job of replacing the blade with no trouble thanks again."
How do I fit a spring to the grass chute deflector guard on my qualcast1200w electric rotary mower
The thing about springs is that they anchor at one or two places. If the chute guard is plastic, you might want to use your ingenuity to devise a way for the spring to attach to the chute and then anchor to the mower body. Pop rivets are great (and inexpensive) for this kind of retrofit. I recommend using a washer with the pop rivet in the plastic to keep it from pulling through with time and fatigue. Remember, need is the mother of invention....so start inventing a work around. I hope this helps :-)
Jul 31, 2016 | Electric Garden
Why does my Mountfield Petrol powered lawn mower cut off instead of idling while I empty grass cuttings?
what engine does it have, how old is it and does in not have a bar you have to hold in to start/stop the engine?
Mar 07, 2015 | Garden
Why wont my mountfield 725m mower go into blade motion
I would check the mower deck itself. This usually happens when it clogs with grass or something got jammed in the belt or pulleys.
Aug 30, 2014 | Garden
Mountfield rotary 4 stroke grass cutter motor 'hunting' continuously.
Norman PRICE THE WORD HUNTINDG IS TRUE THE MOTOR IS LOOKING FOR FUEL ON SOME MOTORS YOU ADJUST THE MIX ON THE CARB CHECK THE AIR FILTER TO SEE IF PLUGED ON A FOAM FILTER YOU CAN CLEAN ON A PAPER YOU WILL NEED TO REPLACE. ANOTHER THING IS HOW OLD IS THE GAS . TODAY THE GAS IS ONLY GOOD FOR A MONTH,
Apr 20, 2014 | Garden
Broken clutch on Mountfield Empress 84104
I'm sorry but I believe you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jul 05, 2012 | Cars & Trucks
How to get the black thing out so that I can restring the weedeater?
Please see the enclosed manual diagrams and instructions paying attention to Figures 11,12,13, and 14 with the accompanying instructions. Read "Fitting A New Spool........" It says to depress the tabs (push in from the sides) to remove the black knob. Here is your manual. I hope this helps.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90524916,GH700%20GH750.pdf
May 07, 2011 | Black & Decker 14" Grass Hog Xp...
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
How do I change the oil in a Mountfield Emperor Lawnmower? I can't see where to drain it.
the drain plug is located under the mower. above the blades. just look for a freeze plug that you can fit a 3/8" ratchet into. Remove the plug, wait for the oil to drain, then replace the freeze plug. You might have to get a water hose and wash the under carriage out and get all the grass off before you'll be able to see it.
Sep 20, 2009 | Garden
How do adjust the mixture on a mountfield 470
Depends on what engine is fitted - but the chances are no adjustment is possible. The mixture is fixed, and the engine has a governed idle - which means there IS no 'idle speed' in the conventional sense.
If mixture adjustment seems to be required, the carb needs cleaning.
Aug 24, 2009 | Garden
Hi Guys,got mower mountfield m4 circa 1988, can find no info whatever, please help,m Rgds Meil,
i need a grass catcher for a mountfield express can i use one from a different model
Feb 28, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
