Question about Philips 50PP9202 50" Rear Projection Television
How much coolant does each gun hold when being replaced
  • Philips Master
  • 8,617 Answers
Just about 16 oz. One 16oz bottle is enough for each picture tube (Gun)
Posted on Jun 23, 2009
Engine Overheating
no other signs just the dash gauge, upset? what if its fibbing?
no steam, no water to ground overflowing overflow tank.
no engine pinging. no lost power, from engine, SIGNS. are key. here.
Did you consider using a IR pyro gun for $20 and find if it is really overheating,? the gun also finds clogged rad tubes, childs play like.
are you loosing coolant. that is when cold actually off the cap
and look down deep in the RAD tank? This matters, most.
which engine,? 2.5,4L or bigger?
what does no coolant going into...., mean.?
it's a loop system.
first off, we need to know does it overheat only parked?
or can you drive it from cold and keep it going and it never overheats
moving fast.?
if the engine stays cool 180F, moving fast , then your stop. and NOW it it overheats, that means the fan is dead.
or a marginal radiator, (Pyro gun to rescue)
Mar 24, 2014 | 1994 Jeep Grand Cherokee
Overflow tank not storing coolant.
Don't jump the gun and replace the head gaskets like the guy recommended...you need to have a technician look at it...can be a minor issue or something totally different. I had the problem with my stratus and paid tons of money to do the heads...never solved the issue and heads were done right. Its was blockage with in the coolant system and was discovered til my water pump went out.
Mar 05, 2013 | 1991 kawasaki ZZR 250
Projector tv color is all wrong I need help
That can either be the Guns are out of adjustment or the CRT coolant needs replacement. You can verify if the guns are balanced properly by simply turning the color level down to zero. The picture should appear all gray like the old black and white Tvs. Any color tint would indicate the guns need to be balanced properly. If they wont balance out then its usually because CRT coolant has failed and that can be verified by looking into the lens of each CRt as its playing you will see bad crt coolant instantly if its present because the image will not be clear and you will see bacterial growth inside the lens if its bad Coolant.
Dec 09, 2012 | Televison & Video
I have a phillips 55pw9363 my picture is hazy. It does not change when I adjust the brightness.
Tv pictures and screen brightness are dulls and have a halo glow to it wright?Yes.The tv CRTS TUBES guns have a chemical call CRTS TUBES coolants are contaminated require changing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a chemical coolant kit to replace it.Kit also came with a tutoring DVD disc showing u how to replace the CRTS TUBES guns coolant chemical.
Apr 03, 2011 | Philips 55PW9363 55" Rear Projection...
How do I open the CRT guns to add/replace coolant?
Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete kit to replaces all three R,G,B CRTS guns coolant chemical replacement the kit also have a tutoring dvd,websites also sell the tutoring dvd alone too.
Apr 02, 2011 | Hitachi 57F500 57" Rear Projection...
The gun part of the wond has a hold. will I need to replace the hold gun section? If so is their a replacement?
Hi, if the gun section is just leaking, then you can replace the washers inside; otherwise, its a replacement, which is not cheap unfortunately; but most guns should fit your machine.
Oct 13, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
How to replace blue gun on Samsung HCM553W
What makes you think Blue tube is Bad ,It may just need coolant fuild changed out.
Feb 19, 2010 | Samsung HCM553W 55" Rear Projection...
Convergence
You can get the coolant kit at the following link which has the instructions on CD for replacing the coolant in the CRTs ( Guns)
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 22, 2009 | Televison & Video
Liquid gel
Thats coolant. Thats bad.
Call a Zenith service place and ask how much to replace that gun and clean up the mess.
Nov 09, 2007 | Zenith IQB50M90W 50" Rear Projection...
Replace the green projection gun
I have almost the same problem, but it was with the blue CRT tube. The coolant leaked onto the underlying PCB and caused short-circuits and sparking or arking. I purchased an exact replacement PCB for the CRT, but I suspected most of its coolant had gone, so I need to re-fill the coolant for the blue CRT to stay cool.
Dec 01, 2006 | RCA Scenium HD65W20 65" Rear Projection...
Philips 50PP9202 50" Rear Projection Television Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
