Question about Homelite Mighty Lite Lawn Trimmer
How to replace fuel lines onmini tiller model #316.292620
Fuel line diagram for troy built tiller
Try reversing fuel lines. They may be connected to the wrong ports.
Jul 05, 2014 | Yard Machines Cultivator
Fuel drips from amber color hose my troy bilt proline tiller
-fuel line is too loose at connector. If there is a claim then retighten it. If no then replace new fuel line.
Good luck
mai
Jul 05, 2014 | Garden
Need diagram to replace fuel line to carberator for a Mantis tiller
get a filter with a smaller diameter end. fuel filters come in all different sized ends so find one that is small enough and then it still may take some work to force it on
Mar 01, 2013 | Mantis 2-Cycle Tiller
PRIMER BULB ON TROY BILT 144 TILLER WILL NOT FILL
look for a cracked fuel line or a split in the primer bulb
May 17, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Honda fg100a wont stay running full of fuel and oil
I had a similar issue. Tiller starts and runs for 20 secs. or so then dies. Found the problem! In turning the tiller on its side to check model numbers etc. the fuel line had shifted inside the tank and was stuck just about at the TOP of the fuel level. When I gently pushed the fuel filter and line back to the BOTTOM of the fuel tank, the tiller now runs beautifully! So, check that the fuel line placement inside the fuel tank is correct.
Sep 29, 2011 | Honda 25cc 4-cycle Mini Tiller
I have a 1996 MTD front tine tiller that was left in someone's shed for about five years. I have emptied the fuel and oil from the tiller and want to rebuild or replace the carburetor and fuel line before...
See if you can find the model number on the engine and then go to the Briggs and Straton web site for the manual for the engine. The tiller manual will not have engine info in it. I hope this helps.
May 31, 2010 | Mtd Products Yard Machines 158CC Tiller
When started will not throttle or dies afetr a minute of running
i love the manits tiller they are very strong and dependable.....they are the same as an echo tc210 i parts will interchange.
your issue is more than likely a plugged fuel syetem, flush the fuel tank, replace the tygothane fuel lines with echo 90014 fuel line, and tank grommet, clean and rebuild the carburetor, install a new tank vent for good measure....untill should spring back to life.....hope this helps and good luck ;)
Nov 24, 2009 | Mantis 2-Cycle Tiller
Clogged fuel lines
fuel lines & filter can be looked at by a small engine shop & find replacements for them the fuel line should be 1/4 diamador
Jun 08, 2009 | Mantis 2-Cycle Tiller
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Replacement of fuel line on the 2 cycle
spray wd40 on line then slide it threw
Mar 29, 2009 | Mantis 2-Cycle Tiller
Homelite Mighty Lite Lawn Trimmer  Logo
24 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
