Question about RCA L46WD22 Television
Audio for 20 seconds or so rca selenium tv problem just answereal painter please check for problem
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Nov 14, 2015 | Symphonic ST420FF 20" TV
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
Apr 21, 2010 | RCA 20F512T 20" TV
Tv speakers are not picking up audio from tv
Try unplugging the unit for 15 or 20 minutes. Sometimes the microprocessor needs to be reset in these units. Thanks
Oct 28, 2009 | RCA P52926 52" Rear Projection Television
How do i Connect RCA VCR to Dynex 20" 480i tv
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
Jan 24, 2009 | Dynex 20" Digital TV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
I have a 20 inch true flat screen RCA tv is about a year old. After you turn in off, later on it turns itself back on. and sometimes it turns itself off after being on for a short perion.
I have the same problem with the same size 20" RCA tv. Mine is a little over 2years old. After turning itself off and on whenever it felt like it, now it blinks off and on nonstop every few seconds and nothing makes it stop......please help
Dec 14, 2008 | RCA 20F410T 20" TV
RCA D770 dont know how to program--lost manual
Check this link to Wiki,
http://wiki.answers.com/Q/How_do_you_program_an_RCA_d770_universal_remote_if_you_don't_have_a_code_search_button
http://download.ethomson.com/english/RCA/ACCESSORIES/IB/D770.pdf
I had trouble with the ethompson link
Turn on device.
Press and hold the button for device you want to program ( TV etc),
press the on/off button and hold until the LED turns on, and then release both buttons.
Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off.
When the device turns off, stop pressing play.
Press REVERSE, wait two seconds and continue doing this until the device turns back on.
To finish programming, press and hold STOP until the LED turns off.
Jun 02, 2008 | RCA D770 Remote Control
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Dec 26, 2007 | RCA 20F420T 20" TV
Loss of Sound
Go into your audio menu, and make sure it is not in the SAP(Second Audio Program). Very common problem when you get good audio on the inputs but not on the RF or tuner input. Good Luck PS Please do not forget to rate this thread.
Dec 07, 2006 | RCA G27647 27" TV
RCA L46WD22 Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
