Question about GroundWork® Pump Sprayer, Brass Wand, 3 gal., 22-1/4 in. H
Where to buy brass wand for 3 galgroundworks pump sprayer
Button on sprayer is sticking with no spray
This is typical behavior or sprayers that aren't looked after. Mine typically last 20 years. After use, you need to empty it, wash it, pump the soap through, rinse it, pump the clean water through, empty it and blow air through it. Then leave it open to dry.
Take the wand off, and take everything apart and soak the parts in hot soapy water in your bathtub. Rinse and dry, rub any o-rings with vaseline.
Apr 23, 2016 | Garden
Model 030XPEG. Why won't sprayer pressurize?
Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden
www.amazon.com > ... > Sprayers
Amazon.com, Inc.Amazon.com : Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden ... Kit with Extension Wand and Adjustable Nozzle(Only for models 1991A, 1992A, .
Oct 08, 2015 | Gilmour Garden
Sprayer parts
need the hand wand were you pump up 3gal
Apr 14, 2014 | GroundWork® Pump Sprayer, Brass Wand, 3...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
The spray stream is not consistent. After 2 - 3
The pump cycles to keep the pressure constant. It could be the impeller---they sell special ones to use with nonaqueous sprays--ie petroleum based. If petro was used at some time, the impeller might be bad.
Mar 01, 2010 | Northstar ATV Broadcast Spot Sprayer 16...
Brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
Clogged and can't get the weed killer to pass through the power wand
EASY FIX!
Hold the sprayer lower than the tank and run it until it sprays. You're done. They seem to lose prime, it usually happens to me when I run it completely out and/or first use (almost year round for us). Mine works fine every time I do this.
If that doesn't work, check the filter on the end of the hose in the tank, blow compressed air through it - NOT BY MOUTH!! Also check for any leaks/pinholes/kinks in the hose - they will **** air instead of solution!
I've had mine for 3 seasons in Phoenix and love it! I've n never had any of the other problems I listed personally. Handle the liquids like you handle gas for your lawn mower, etc:
1) Don't let any dirt to get in the solution.
2) Wash the system before storage ESPECIALLY AT END OF SEASON by spraying clean water through It for a couple of minutes or so and rinsing the tank. STORE INSIDE FOR THE WINTER if it freezes, it may trash it. Leaving anything stronger than Roundup (TM) in it for more than a week or so may eventually damage the plastics and/or seize the pump too.
Apr 30, 2009 | Cepia "" Hands Free Power Sprayer
Sprayer Support
Measure the exact amount of material required for the job. Adjust the spray precisely - from coarse, drenching coverage to very fine mist to a long range pinpointed stream. Start and stop the spray quickly and at will. Prevent over-spraying by using the long-reaching hose and spray wand. Spray up or down as well as underneath leaves (where most insects and plant diseases can be found). Buy concentrated lawn and garden treatment materials, which in many cases is more cost-effective than the pre-mixed versions.
Aug 27, 2008 | Chapin Industrial 3 Gallon Viton...
GroundWork® Pump Sprayer, Brass Wand, 3 gal., 22-1/4 in. H Logo
69 people viewed this question
Top GroundWork® Garden Experts
Dennis Key
Dennis Key
john h
Are you a GroundWork® Garden Expert? Answer questions, earn points and help others
