Question about HP LaserJet 1022 Printer
Unable to re-start the spooler or restart the machine.
I am having the same issue and it started yesterday when I tried to print a pdf. I have a 1022, not a network printer.
  • phxswsun Jun 29, 2009
    I need an HP 1022 spool error fix for Windows Vista. The solution posted June 23rd by Hench Toast does not work for Vista. Any help out there?
    Scholar:
  • 41 Answers
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website
Posted on Jun 23, 2009
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Go to START
Choose RUN
Type SERVICES.MSC
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Hello, I have Dell Latitude D630 running on windows 7 (64 bit), I have a adobe reader ver . 9.3.4, and an HP J6413 All in one print scan fax. The issue as above seems to be larger pdf files, it start to...
pls check how much size file you are giving to print if the file range is too high in mega bytes it will take long time to print and cancel but the same print u r printing in a simple printer it prints in much more speed so pls check installed driver and spooler service
Sep 16, 2010 | HP LaserJet 1022 Printer
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Lj 1012 or 1022 hangs the print spooler
Since you're mentioning policies, you've probably got a bit more background than most.
Check your update histories. You're looking for the same correction/time-factor with both XP/Vista.
Verify the driver version. Download the newest driver. Try it on one machine. Try the previous one.
Look at other printer drivers installed. Multifunction printers are the worst for conflicts and hogging resources.
May 14, 2009 | HP LaserJet 1010 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printer Logo
408 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
