Question about Lincoln Power Arc 5500 Generator/Welder
Adjust governor on linclon welder 5500 with 9hp. robin Subaru ex27 motor
2 Suggested Answers
  • 17 Answers
SOURCE: What do i use to power my linclon ln-25 suitcase mig welder?.
no it cannot be
Posted on Apr 21, 2012
How to adjustment static governor on a quantum xe 40 briggs and Stratton lawnmower please thanks Robin
1. Move throttle control to wide open throttle position,
Fig. 45.
2. Loosen lever adjusting screw. Item 8
3. Turn governor crank counterclockwise and hold.
4. Torque lever adjusting screw to 15 in. lbs. (2 Nm.).
Mar 31, 2015 | Garden
What is causing subaru portable generator to overrev?
Could be the return spring on the regulator has come off.
Oct 05, 2014 | Pramac Generator 5000 Watt Subaru EX27...
I have a homelite LR4300 with the 7.5 HP Subaru engine. The governor is not working. Whats the poblem?
Unclear when stated that there is a governor issue? I assume you have a Robin/Subaru 7.5 H.P. engine model EY280YD2510 with erratic behavior leading up to stalling out when a load is applied or the generator is at no load status after several minutes of run time?. Couple of things to check would be starting with the fuel system. Is there stale gas in the fuel tank? Have you verified fuel flow from tank? Is the fuel cutoff valve free of debris? Is the carb fuel bowel been removed and inspected for varnish? Is the air cleaner clean? Next, Ignition system. Have you inspected the flywheel for excessive rust? Have you reset the air gap on the ignition module? Does the on/off switch work (measured with a meter for continuity?) Any visual signs of damage with all wiring or the ignition module itself? I once thought I had an governor issue where the issue ended up being that the flywheel was corroded to the point that once the engine was fully warmed up the control module would contact the rust build up on the flywheel causing engine surges no matter what the load was on the generator, and at times would stall the engine. Clean flywheel off if necessary and reset the air gap on the ignition module. If that fails then inspect the governor spring (the top spring on the carb. linkage assembly) for excessive rust that will change the tension on the governor arm.Replace if in doubt! When doing all this inspecting ensure you have fresh fuel, oil, air filter, spark plug gapped correctly, and ignition module that has been tested as sound! These Robin engines are smooth running heavy duty engine that will perform for many years if taken care of. Good luck!
Dec 07, 2013 | Robin Subaru Electrical Supplies
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
Mar 03, 2013 | Miller Welding Tools
My coleman started running at a super high rpm. I know it's the governor, but how do I adjust?
It sounds like the governor arms internally are broken, can you feel any resistnce? if not then it will need a tear down to fix
Nov 06, 2012 | Coleman Powermate Subaru 5000W Portable...
Subaru rgx3600 generator only producing 5volts
Sir take out the stator assembly from the engine and clean it properly from inside with cotten cloth moist with gasoline and then clean the roter while fixing it back mind the gap between the rotor and stator sometimes there is dirt or other material sucked inside the alternator which diaturbs the megnetic poles as a result the stator does not produce enough charge for exsitation
Aug 17, 2012 | Robin Subaru Subaru RGX3600 Portable...
Miller welder starts fine bur appear to run out gas need help adjuting linkage to fuel control
you need to adjust the throttle governor on the side of the carburetor you will see a adjustment screw do a weld to get the welder to runs at high speed then adjust the screw till it runs continuously, if it still dies out change the fuel filter and try again drain the carburetor bowel if it's diesel replace fuel filter and run fuel threw the water trap.
Nov 18, 2009 | Welding Tools
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
ENGINE OVER SPEEDS WHILE RUNNING
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Dec 03, 2008 | Coleman Powermate Premium Plus 6250W...
Lincoln Power Arc 5500 Generator/Welder Logo
70 people viewed this question
Top Lincoln Welding Tools Experts
Robert Smith
Robert Smith
Matt Olenzek
Matt Olenzek
Steve
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
