Question about Briggs & Stratton Garden
I have a B&S Quantum 6 hp pressure washer and the primer bulb is missing and the gas leaks out of the side of the engine.
  • 376 Answers
SOURCE: Gas for 6.5 quantum
It's a four cycle, gas only. You only mix gas and oil on two cycle engines where there's no place to put oil such as trimmers and blowers.
Posted on Jun 17, 2009
jimboz4
  • 305 Answers
SOURCE: need owners manual
hi, have a look on this site...it has just about every owners manual
http://manuals.syntigroep.nl/manuals.htm
Posted on Jul 23, 2009
  • 583 Answers
SOURCE: Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Posted on Jul 25, 2009
  • 6 Answers
SOURCE: oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Posted on Oct 03, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Posted on Apr 02, 2010
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
Hello my question is on my powerwasher the primer rubber button has like melted away how would that be replaced
You need to go to a small engine repair center to find the primer bulb that fits on your motor. It will depend on what motor and carburator you have. They are fairly easy to replace. The primer bulbs 'melt' or go soft because of ethenol in gas. You should expect to get one to two years out of a bulb so you may want to get an extra or two.
Dec 26, 2012 | Briggs & Stratton Gas Pressure Washer...
My washer will start but only run for a few seconds......unless you hold the primer bulb in
The primer bulb has a pin hole in it:
This is what you need:
http://www.mymowerparts.com/partdetail/1079/14606.php
All local lawn mower repair / parts sources have this part in stock. This is a common issue with primer bulbs that you have to hold the bulb in so that it will run. When you do that your stopping it from drawing air through the hole in the primer bulb so it operates normally. Replace the primer bulb and it will be fine.
Thanks for choosing FixYa,
Kelly.
Aug 14, 2011 | Briggs & Stratton Gas Pressure Washer...
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
Engine wont stay running
It is a diaphram carb. Doe's the primer **** straight gas or does it have air bubbles in it? If it has bubbles in it then it is a leak in the fuel line.
If not then Unhook the intake fuel line and pump the bulb until all of the gas is out of it. Then pour the gas out of the tank and rinse it out with new gas. Pour in new gas and it should be ok.
May 23, 2010 | Briggs & Stratton Power Products 1539...
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Jul 25, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Gas for 6.5 quantum
Jun 17, 2009 | Garden
Garden Logo
320 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
